I'M WANTING TO CHANGE MY 71 LEMANS FROM AN AUTOMATIC TO A 4 SPEED. I HAVE SOME QUESTIONS I HOPE THAT SOMEONE COULD ANSWER.
1. THE ENGINE IS A 350 PONTIAC ENGINE. IS THE CRANK ALREADY DRILLED FOR A PILOT BEARING? 2. I HAVE A FLYWHEEL WITH A CASTING # 9779233. CAN ANYONE I-D THIS NUMBER? DOES IT USE A 10 1/2 INCH CLUTCH OR 11 ? DOES IT MATTER? |
the crank is drilled for the pilot bearing.
If the flywheel can fit a 400/455 crankflange, it will fit the 350 crank flange pattern. 10.4 vs 11.0 Pressure Plate...I dunno...is it a dual-pattern flywheel? "11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
WELL, I CAN REST EASIER NOW THAT I KNOW THE CRANK ISN'T GOING TO BE A PROBLEM!
AS FOR THE FLYWHEEL, IT CAME OFF OF A 69 GTO. NO, IT ISN'T A DUAL BOLT PATTERN. THANKS FOR YOUR INPUT! |
