Old 02-03-2005, 03:35 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Will th 04 wheels fit on older GTO's.
hobbygto65's Avatar
Old 02-03-2005, 09:59 PM
Big Injun's Avatar
Big Injun Big Injun is offline
No, different bolt circle.
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 02-04-2005, 10:26 AM
mwritter's Avatar
mwritter mwritter is offline
Correct...I believe the bolt pattern is actually metric. They aren't going to fit much of anything made in America.
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
Old 02-04-2005, 11:20 AM
salokin salokin is offline
The new GTO's bolt pattern is 120x5mm. The old school Pontiacs are 120.6x5mm. I have fit 120.6x5mm wheels on an 04 GTO with no problems. You realize the difference is a width of a hair right? The debate is on, but it's been done.
Old 02-04-2005, 11:48 AM
Droptop64 Droptop64 is offline
On Vacation
They are a different bolt circle, and the general consensus is that eventually, they will cause the studs to break due to the constant stress of being pulled (outwards) on the old cars. Another problem would probably be the offset required to fit the new GTO's. It's a 17X8 wheel with a 48mm offset. The bolt pattern on the new goat is 120 mm, and the old ones are actually 120.65.mm or 4.75". This has been discussed ad infinitum on the LS1GTO forum.
