Old 06-05-2000, 08:18 PM
Larry 67 Larry 67 is offline
What exactly doe's a vacuum gauge tell you. I've been told if you know how to read, and understand them, they will give alot of info about the condition of your engine, other than a vaccum leak.
Besides looking cool on the console, what are all of it's functions. I will be installing it in a 67 GTO 400, 4barrel, 400TH dual gate.
This car is being restored for cruising on the street, I don't plan to race it at the track.
Thanks for any info you experienced guys can pass along. Take care. Larry
Cruise On
Cruise On!!! http://kurtspontiac.homestead.com/Larrys67GTO.html
Cruise On
Old 06-05-2000, 11:46 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
A vacuum gauge tells you how hard your engine is working. Green means light loads or good mileage. Yellow moderate work or poor mileage. Red Hard work and no mileage.
The harder on the gas the poorer the mileage. When you put the pedal to the floor. The gauge will drop to the bottom of the red.
Try calling CRUSHPROOF! 512-386-9889
Old 06-06-2000, 08:44 AM
if the guage fluctuates alot [ with a smooth idle cam] it can mean burnt or tight valves, retarded timing ect. they are also used to set idle mixture. mike
former." --Albert Einstein
- Winston Churchill
Old 06-06-2000, 08:58 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
Since we are on the subject of Vacuum gauges, who has a 64-67 GTO that they "KNOW" came with this option? For years we have been puzzled as to whether the gauge got a chrome adapter for the console. We know for sure the 65 Big Car had this adapter, but there is no part number in the parts books for the GTO, yet most ask for this adapter when installing a Vacuum gauge.
Old 06-06-2000, 08:31 PM
Blackcat's Avatar
The vaccum gauge was a Dealer installed option. An old Friend Who worked at a Pontiac dealer told me. Lots of people liked the Grand Prix look. So to sell a car they would Gladly install the vaccum gauge for the buyer. (for a small fee)
Old 06-12-2000, 04:20 PM
Thanks Guys for the reponses. A friend at work brought in an article from the Jan 74 Hot Rod mag. It's titled What Do All Those Instruments Mean, and really covers the vacuum gauge well. The bracket mentioned that was used in the GP installation...can the same one be used on my Goat console??? If so where can I obtain one..are they a reproduction, or do I look for an original?
If anyone is interested in the Hot Rod article I mentioned let me know. Thanks again...and take care.
Cruise On
Old 06-12-2000, 04:43 PM
Blackcat's Avatar
Larry, The bracket mentioned is from a 62 Big car. GP, Cat, Bonnie. You will have to drill 3 holes. One large and two small. Follow the pattern on the console backside. the gauge will work without the bracket. It just won't look as good.
Mr. Z
Old 06-12-2000, 05:25 PM
Ccass's Avatar
Administrator
We reproduced that bracket way back in 1986. It is our part # PYU300. $24.00 In the parts books it is listed as a 1965 fullsize only "adapter".
http://performanceyears.com/ponor4.htm
Old 02-16-2005, 04:21 AM
analytical analytical is offline
I'd like that article please.
Learn By Doing!
Old 02-16-2005, 07:37 AM
Rugratman's Avatar
Rugratman Rugratman is offline
Being a rookie to the vacume gauge, How did they hook up to the engine, just a small hose from the manifold to the gauge?
If I did not want to mount the gauge to the console, can you check the vacume with a hand held gauge? Should I have done that anyway?
........I'm just learning as I go.......
Old 02-16-2005, 08:01 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by rugratman:
If I did not want to mount the gauge to the console, can you check the vacume with a hand held gauge? Should I have done that anyway? </div></BLOCKQUOTE>
yes manifold vaccum is what is supplied to the guage.
and yes a handheld unit does the same thing, just not a pretty.
mike
- Winston Churchill
Old 02-16-2005, 09:20 AM
ctgross ctgross is offline
Wow, talk'n about digging up bones, just realized this post started in 2000! I'd like a copy of the article too, if he can still find it. Got one of those gauges on my 66, but I didn't use the small mount because I'd read that they were only used on the big cars.
CT Gross---66 GTO
"Its never too late to have a happy childhood"!
I told my dad I was going to stop raising hell, and he called me a quitter!
Old 02-16-2005, 09:23 AM
george kujanski's Avatar
To add some info: A vacuum gauge is connected to manifold vacuum & can tell you quite a few things about the engine.
First, A stock engine should have about 18 in. of vacuum (actually measured in in. of mercury). A much lower figure indicates probable vacuum leak.
A pointer that drops in reading periodically may indicate a stuck open intake valve or several bad valves.
As mentioned above, the OEM type of gauge had a red/green scale, the green corresponds to the high readings which occur at idle and part throttle conditions. The deeper you get into the accelerator or load the engine, the vacuum goes down (red) showing poor economy.
A typical use during tune ups is when adjusting the idle mix screws on a carb. The best idle is usually at highest idle vacuum.
In modern cars, a vacuum gauge of sorts is built into the system, it's called a MAP sensor, (manifold absolute pressure). It gives the computer a output voltage from 0 to 5 volts, indicating manifold vacuum.
George
Old 02-16-2005, 09:57 AM
Bill H's Avatar
Bill H Bill H is offline
Vacuum tuning info.
http://www.centuryperformance.com/vacuum.asp
67 GTO HT
1968 400 Engine YE
TH-400
#13 Heads -J069
Q'Jet .
8.2 Eaton Posi/3:55
Old 02-16-2005, 10:18 AM
Bill H., thanks, that's a great link!
CT Gross---66 GTO
Old 02-16-2005, 10:39 AM
6t7gto's Avatar
6t7gto 6t7gto is offline
bill h.
thanks for the link.
i just picked up a vac gauge to tune my lemans and needed to refresh my memory.
david
Old 02-16-2005, 09:11 PM
Brian D'Amico's Avatar
Brian D'Amico Brian D'Amico is offline
Is there a certain place on the manifold that tie into?? I have a Vacuum gauge next to my Temp and oil pressure gauges. I have a Pontiac performer intake. Please let me know where I should run a hose from... Thanks!!!
Brian D'Amico
Old 02-20-2005, 05:52 PM
TopdownloGTO TopdownloGTO is offline
George </div></BLOCKQUOTE>
George, is this condition at idle?
Old 02-21-2005, 08:55 PM
Yep. As mentioned in the link above for stock cammed engines. Substantially lower could indicate a vacuum leak. Also as mentioned above low idle vacuum could also cause your power enrichening circuit in the carb to respond, causing more issues.
You should try to maximize the vacuum by adjusting the idle mix screws, adjust the idle speed to the proper value, And then note the vacuum for your engine. That'll be your baseline.
Vacuum will go lower when the engine is under load, and go higher when coasting (throttle being closed).
George
