Old 03-24-2005, 08:09 PM
nicko72gto nicko72gto is offline
http://www.angelfire.com/fl4/pontiac...sspecials.html for the package on this link how much does the engine have to be bored? my 400 is bored 0.030 over right now but i think were doing an other 0.010 to make it 0.040. do they sell you the size of pistons for your bore? can someone please help me?
thank you
thank you
Old 03-24-2005, 09:40 PM
Doug Christie's Avatar
Doug Christie Doug Christie is offline
Yes they do. Contact P-DUDE or others on this sight or put an ad in the for sale section.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something."
Old 03-24-2005, 11:01 PM
so for me would 400 0.040 over pistons come with the package?
Old 03-25-2005, 10:25 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Nick Markey:
so for me would 400 0.040 over pistons come with the package? </div></BLOCKQUOTE>
Contact Ken Keefer at http://www.angelfire.com/fl4/pontiac...chineshop.html
Old 03-25-2005, 10:43 AM
PONTIAC DUDE's Avatar
Thanks Doug. Your commision check is on it's way. LOL.
Yes we have engine kit packages.
From stock to hi-performance. Most any bore & crank size available.
Old 03-25-2005, 08:32 PM
Balanced Rotating Assembly: Now you can turn your Pontiac 400 into a 455 Torque Monster with this complete rotating assembly!
New Eagle 455 Crankshaft 4.210 Stroke cut to fit
Custom Dude Shim Kit w/ Main Bearing Set
Connecting Rod Bearings
Stock Resized Rods w/ ARP bolts
Flat top Quality cast 455 Pistons
Quality Hastings Rings
Total Assembly Balanced to factory specs.
so how much more power will the extra cubes from this package actually make on my 400 right now. 69 judge ram air three heads and cam, roller rockers, two inch headers, performer rpm intake, and 750 edelbrock, borg warner super t-10 4 speed and 3.73 gears with posi in a 72 gto?
what knd of power can i expect to make? and what can i expect to run?
