Old 05-20-2000, 11:59 AM
Judge Smails's Avatar
Judge Smails Judge Smails is offline
Was getting ready to put the 462 in the '80 when I noticed the crank pulley stuck out almost a full groove past the wp pulley. I thought all '69+ waterpumps, dampers and front covers were identical, but I seem to recall there was briefly a short pump in between the 67-68 and later 69-up pumps. Am I going senile? I have the exact same pulley part #s on it that came stock on my '71 so something ain't right.
Old 05-20-2000, 01:50 PM
Judge, '69 model was the year for short waterpump (early) & tall waterpump (late). By using the tall '69 or later w/p, you are correct, that you can interchange '71 & later pulleys on your '69. With time, it is getting increasingly difficult to find some of these pulleys.
Old 05-20-2000, 02:09 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
"Hey Smails, 50 bucks says you slice into the woods"
On a more serious note, Perfomance Years does sell the short snout water pump for early '69s. Its p/n is GME39A and sells for $30.00
Ames Performance also sells it under p/n N140NP for $29.00
You might even try your local auto parts stores. You will be suprised at what they have in stock for older Pontiac's
"Run wild with an Indian, not with the crowd in a Chevy"
Check out my restoration at http://members.aol.com/jetmech15/gto
Less said,,,,,,,, Less mended.
Old 05-20-2000, 03:13 PM
Gambling is illegal at Bushwood, sir, and I never slice.......DAMN!!
I actually have the opposite problem...ended up with the "short" pump (maybe it saw Hillary in a miniskirt?)-- cast in March I think. Problem is, it's a '74 block with '71 #96 heads and I'm using all '70s accessories. Luckily the long ones are a lot more plentiful. Thanks all.
[This message has been edited by Judge Smails (edited 05-20-2000).]
[This message has been edited by Judge Smails (edited 05-21-2000).]
