Old 03-02-2005, 09:20 AM
MJGIII MJGIII is offline
I blacked out my grilles years ago and now want to restore them. I've seen them either all silver or silver/black. Anyone know what is correct? They are non-hideaways and the valances don't have grilles.
Old 03-03-2005, 12:08 AM
Ron Landis's Avatar
Blacked-out were for Judge optioned cars. Other GTOshad silver grills. Ron
Old 03-03-2005, 01:46 PM
tremo's Avatar
tremo tremo is offline
The previous owner of my '69 Custom S painted the grilles black and the paint is chipped now. What's recommended procedure to restore them back to factory silver? Repaint them the appropriate color (chipping problem again?) or strip the paint?
It also looks like I need to pull the radiator to get the grilles out, is this true?
Thanks!
Jim.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor
* Engine alive and kickin' March 2nd, '06
* RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers
* QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi
* Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+'
Old 03-03-2005, 02:02 PM
robz's Avatar
robz robz is offline
Strip them well (I have used Easy Off Oven cleaner on a few I did with great success). Spray them well, and let them soak overnight in a plastic bag. You may have to repeat if alot of coats of paint have been used. This will remove all paint down to palstic without harming them Remove all trim around them if there are any. I then spary painted them with two coats..
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
Old 03-03-2005, 02:17 PM
tremo's Avatar
Excellent, thanks robz! I'll try that as I'd much rather go back to the stock gray color, which I can easily see as I use my fingernail to scrape the black paint off (so there's probably only one coat).
Do I have to remove the radiator to get to the grille "hold-in brackets" or can I remove the headlight and bezels and get to the brackets by removing that plastic cover under the hood behind the radiator (it sits behind the front bumper)?
My '69 Service Manual shows how the grilles are held in, but no details on how to remove them/what needs to be pulled to get to the brackets. I'm hoping that once I remove the headlights and hold-in brakets I can remove the grilles via the front bumper...
Thanks!
Jim.
Old 03-03-2005, 02:25 PM
robz's Avatar
Sorry, tremo, can't help with the grilles on a Lemans, but on the GTO, you can access the bolts from the top near Rad support (Endura bumper) but on the Lemans it may be different. Someone will surely be able to shed some light on this...
1969 Grand Prix SJ
Old 03-03-2005, 02:33 PM
tremo's Avatar
OK, thanks. So on the GTO can you pull the grilles thru the front bumper once you loosen the bolts on those brackets? If so, I bet I can too...
Jim.
Old 03-03-2005, 02:53 PM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
Tremo...I think you have to take off the front bumper on the '69 LeMans,Tempest and Custom_S to remove the grills?Its a lot more difficult and less room to get in behind the grills on the LeMans Chrome front bumpers.
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Old 03-03-2005, 07:01 PM
goatless's Avatar
goatless goatless is offline
Tremo, you need to remove the whole bumper assembly to get the grills out. You need to remove the lower valance to get the bumper off. I've done this procedure more times than I care to remember.
I don't know if the Custom-S grills are painted the same as the Lemans. My Lemans grills, which I believe to be original paint, are kind of a metallic gray background with silver highlights on the front surface of the horizontal bars.
1966 GTO
Old 03-04-2005, 09:21 AM
tremo's Avatar
Thanks guys. Bummer...I was hoping it was easier. Oh well, I'll work on this as I get to the bottom of my list.
Seee-ya,
Jim.
Old 03-04-2005, 12:45 PM
Red Goat's Avatar
Red Goat Red Goat is offline
So what are the correct colors for 69 GTO, non Judge grilles. I need to detail mine also.
Tim.
69 GTO 400, 4-Speed, Matador Red
69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack
72 Trans Am, 455HO, 4-Speed, Lucerne Blue
73 Trans Am, SD-455, 4-Speed, Brewster Green
73 Formula, 455, 4-Speed, Ascot Silver
73 Formula, 455, Navaho Orange Survivor
Old 03-04-2005, 01:04 PM
robz's Avatar
They are painted silver. If you have hideaways, the inside of the squares on the headlight covers is painted semi-gloss black (to have the effect of having them hollow, like the grilles) and the rest is also silver. I have use Dupli-Color Steel wheels silver (WP 316) with Krylon or Duplicolor Semi-gloss Black. Here's what the came out like.
1969 Grand Prix SJ
Old 03-04-2005, 01:14 PM
bxm1968's Avatar
bxm1968 bxm1968 is offline
Tremo
The Custom S Grilles are that same argent silver color as the GTO, and have the same blacked out color/effect for the inside of the squares as the GTO. You will have to remove the entire bumper assembly and believe me it is not fun, since the bumper is substantially heavier than the endura. I'd recommend having a friend help you.
We All Shine On
