Old 09-01-2002, 12:50 PM
GTO JOE 64 GTO JOE 64 is offline
Can anybody tell me why when I turn off the motor when it is 220 temp. and try to start it again I get starter drag and it won't start untill it cools down? Thanks:
Old 09-01-2002, 03:48 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Starter Solnoid heat soak. Move or shield the solnoid.
Old 10-02-2002, 05:53 PM
Dave Schiffers's Avatar
Dave Schiffers Dave Schiffers is offline
I wired in a remote solnoid(by-passed the one on the starter), didn't work. Tried heat shielding it, didn't work.
Finally broke down and bought an IMI High Torque Starter. PROBLEM SOLVED !!!
Old 10-02-2002, 06:28 PM
David Jones's Avatar
Initial timing to high?
http://kurtspontiac.homestead.com/DavidJones69GTO.html
Old 10-03-2002, 07:50 AM
Half-Inch Stud's Avatar
idle & primaries are too lean. Richen them for cooler idle&cruise.
check oil and coolant level.
run a factory flex fan. No clutch or aftermarket stuff. Assume you have a good fan shroud..
Starter mating surfaces need to be filed clean of runt and paint for good ground path.
Solenoid gets blame...I say naw. Replace questionable battery cables & locate the BATT NEG cable to the lower Transmission Bellhousing bolt.
Oh, It'll start.
H.I. S.
"11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
