Old 05-17-2005, 11:10 AM
breakneck88 breakneck88 is offline
Help i think i messed up!! i just put my 400 into my 67 vert, the motor is a 73 with a windage tray! when i installed the motor i didnt even think about the dipstick tube. now the motor is in the car and i dont know if i could put it in! i am not sure which one of my tubes to us with the windage tray!!! i have an aftermarket tube, a 67 326 tube ( numbers matching) and the 73 . my question is do i need to pull my motor out so i can add the lower tube or is there a tubethat i can tap in from the top the wont hit the crank any help is appreciated!
67 'Vertible Bird and an '85 T/A.
Old 05-17-2005, 11:34 AM
68lemans462's Avatar
68lemans462 68lemans462 is offline
the oil pan has to come off to install the lower tube. This requires removing the engine.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 05-17-2005, 11:50 AM
Bad Karma's Avatar
Bad Karma Bad Karma is offline
Oh that sucks
72 Lemans
Old 05-17-2005, 11:57 AM
Pontiac Poor's Avatar
Pontiac Poor Pontiac Poor is offline
Yup, that does suck. Ranks right up there with forgetting to put in the oil pump drive shaft...although that can be done from topside with some modifications.
Don't be jealous that I've been chatting online with babes all day. Besides, we both know that I'm training to be a cage fighter.
Old 05-17-2005, 12:01 PM
meanolgoat meanolgoat is offline
Ok. Lets see how much grief I get over this post.
Leave the lower tube out. Cut an old Dipstick short so it will not protrude into the pan and hit the crank. Store the correct dipstick in the trunk, and only use it to check the oil level.
How to determine the oil level. On the initial fill add the correct amount of oil (5 or 6 qts), and make sure the filter is full. Use the correct length dipstick and mark it where the oil level is.
Been there, done that. Last time I let a builder assembly one of my engines.
Old 05-17-2005, 12:12 PM
chiphead's Avatar
chiphead chiphead is offline
That may work, but doesn't the lower tube direct the stick into the pan sump? Without the lower tube, you don't really know where the stick ends up in the crankcase??
Old 05-17-2005, 12:13 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Meanolgoat:
Been there, done that. Last time I let a builder assembly one of my engines. </div></BLOCKQUOTE>
You can chachi it in or do it correctly, its up to you... If it was a Ford motor, I might consider the suggestion above..
Old 05-17-2005, 03:52 PM
ChrisTransAm78's Avatar
ChrisTransAm78 ChrisTransAm78 is offline
The dipstick (if you can get it in) should only go so far and always go that far. If its a first time fill, you could mark it and be relatively sure that that is the full line. Heck, even if you know its a 5 qt pan then your still good. All your using it for is to test whether the motor is burning oil etc. I like that suggestion as I know tearing out a motor is WAY TOO MUCH FUN!
http://www.christransam78.com/
Old 05-17-2005, 06:43 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Ok. Lets see how much grief I get over this post. </div></BLOCKQUOTE>
No grief from me! I would do exactly as you say- and wait to find out what else I screwed up to REALLY need to pull the engine.
Old 05-17-2005, 06:54 PM
Philcol Philcol is offline
Been there too. I made a round dipstick handle and put a bend in the dipstick so it will always go into the pan and not hit the crank etc. I engraved an arrow on the dipstick that points toward the engine head to index it each time. Then I made up a short dummy stick to put in the tube as a plug. I store the checking stick under the hood on top of my radiator brackets.
Phil
"dreamed I was wide awake........woke up and I was sound asleep"
Old 05-18-2005, 03:33 PM
joegio's Avatar
joegio joegio is offline
Did you put the extension from the tube to the tray.
So then I said to myself "what would I do if I was me" ...
