Old 05-06-2003, 07:48 AM
rikstr7 rikstr7 is offline
Does anyone know a source for a kickdown switch on a 68 Firebird 400 Automatic? The switch was missing off the car when I began to restore it. I called a few tranny and auto stores with no luck. All advice welcomed.
Old 05-06-2003, 10:47 AM
PLAY400's Avatar
PLAY400 PLAY400 is offline
couldn't find 1 either. use the B&M T400 switch that Summit sells. alan
Old 05-08-2003, 11:23 AM
engineer engineer is offline
haven't tried it, but can't you mount a kickdown switch on the pedal like the gto or maybe just use a gto pedal setup instead of the firebird? Are the acceralator pedal setups that different? I have several gto pedals if you post a firebird pedal setup.
Old 05-08-2003, 01:22 PM
PLAY400's Avatar
Tried using newer style pedals with the switch and didn't have the room to make it fit.
