Old 03-04-2003, 05:49 AM
ta406pont ta406pont is offline
Hello guys what do you think would be a good combo to run for a tranny and converter in this car and engine combo??I'm getting ready to finish the car for spring and need a tranny..Any suggestions
Heres the car
1979 T/A
3165 lbs w/me in it and full fuel cell
Moroso drag springs up front
Calvert Caltrac Bars w/Calvert split springs in rear
with QA1 12 ways at all 4 corners
29x10.5/15 slicks on rear w/15x10" Pro Stars
15x3.5 Pro Stars up front
12 point cage
9" Ford w/4.11 and a light spool
Anything Else just ask
Heres the engine
408ci
4.160 bore
3.750 stroke
stock 350 crank 10/10"
stock rods/ARP bolts peened/polished
Flat top TRW's
lightweight pins
Custom ground Solid Comp Cam
[email protected]" in/[email protected]"ex
567"in/587"ex
108 LSA/ICL
1.6 roller rockers
Ported "16" flow 282cfm @ 600" in / 210cfm @ 600" ex
Compression 12.8:1
Pro Systems 950 HP
1 7/8 Super Comp headers
Full Mandrel Bent 3" exhaust
Ported T2 intake
Full MSD ignition
Anything else just ask me
This motor dynoed last summer made 523hp @6000 rpm and 502 ft lbs @ 5000rpm I still have dyno sheet so if you need to know more torque specs I can tell you.Thanks for any help..Also does anyone have a idea of what this car should run roughly.??
" If I ain't Loggin' Hard then I'm Drivin Hard "
Heres the car
1979 T/A
12 point cage
Heres the engine
408ci
4.160 bore
3.750 stroke
Flat top TRW's
lightweight pins
567"in/587"ex
108 LSA/ICL
1.6 roller rockers
Compression 12.8:1
Pro Systems 950 HP
Ported T2 intake
Full MSD ignition
Old 03-04-2003, 06:54 AM
fasteddy's Avatar
fasteddy fasteddy is offline
Almost light enough for a Glide but not quite. If it were me, I would run a TH350 with good strong innards or a race-prepped TH400. That combo is going to like a stall of around 4500-5000 in an 8 inch converter. Buy a good brand--I use Continental but there are others with really good reps. Good luck.
fasteddy
fasteddy
Old 03-04-2003, 07:42 AM
Half-Inch Stud's Avatar
All things considered...don't much reveal the Trans-choice....until :
Pro-systems 950HP....clearly TH400 only.
Pro-systems 950HP....clearly a LARGE Diameter converter with an intentional stall selection.
Us simple folks on this board justa don't realize that Converters saturate...the smaller they are, the less ultimate torque they can transfer.
That would be my present converter-selection issue for 650HP, and a 455 with 5200RPM shiftpoints.
Half-Inch converter Stud
"tbdET/1xxMPH/1.xx 60foot/28"/3.54:1/10"/469 #48/Flat HYD/DualQ-Jets/Offyl/3xx0Lbs
11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/469 #48/FlatHYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/469 #48/FlatHYD/Q-Jet/Torker/3650Lbs
12.70/103MPH/1.71 60foot/28"/4.10:1/12"/469 #48/FlatHYD/Q-Jet/Torker/3950Lbs"
Old 03-04-2003, 07:48 AM
Scott65's Avatar
Scott65 Scott65 is offline
I'll be the blacksheep but.... 1.96 low gear glide and 9" 4500 stall. I've used 'glides around 3200#'s and seen improvement over Th350 and 400's even with factory gear ratios. Good luck whichever route you take.
'65 Tempest 467 3650# [email protected]
Old 03-04-2003, 09:46 AM
fasteddy's Avatar
With a 3.75 stroke and making peak torque at 5000, it sounds as though your shift points may approach 6500 -7000. That would be meer speculation. I do not think you can compare a 455 to this combo as far as drivetrain components go. I thought about the glide but I have aleays heard that 3000 lbs and under was the magic number. No?
fasteddy
fasteddy
Old 03-04-2003, 10:01 AM
Brian '74's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> stock rods/ARP bolts peened/polished <HR></BLOCKQUOTE>
How high are you planning on turning this motor?
Old 03-04-2003, 01:27 PM
Thanks for the ideas so far guys I appreciate it,keep em coming.I don't plan on shifting this motor anywhere past 6400-6500 rpm,I personally did'nt want to run stock rods but I did'nt have enough money at the time of assemblly for a good set so I worked with what I had,so far the engine has close to 15 dyno runs on it,but no street or track time so hopefully it will stay together.
Thanks Rob.
Old 03-04-2003, 03:30 PM
Goatman Goatman is offline
On Vacation
TH400 since you'll need to keep the RPM down, the extra gear will help.
9" or 10" converter. Try around 4000-4400 stall. Get it tight.
Chance favors the prepared mind.
Old 03-04-2003, 03:38 PM
Thanks for the suggestion Bruce much appreciated,how will a 4000-4500 rpm stall act on the street??
later Rob.
Old 03-04-2003, 04:35 PM
On Vacation
Depends on alot of things Rob. If the converter is "right", it will creep in idle, just like a regular car. You will notice the engine revving higher, of course, and the converter won't be fully locked untill you reach the stall speed (or at least close to it), which will generate a little more heat. A good trans cooler will be mandatory and Mobile 1 trans fluid is always a safe bet. I use it.
Generally, the bigger the converter, the tighter it will act. Normally, I would recommend ATI, but lately, they have been difficult, if not impossible to deal with reguarding converters in a couple of friends' cars. Not sure what they're doing over there. But, with dyno sheets in hand, you should be better off han my friends were.
Old 03-04-2003, 04:46 PM
Thanks again Bruce for the info,I will give ATI a call tomorrow and see what they have to say,and I'll let you guys know.The car already has a large B&M tranny cooler installed so it should help keep the temps down.
Thanks again Rob.
Old 03-04-2003, 04:47 PM
Bartman Bartman is offline
If you are just going to bracket race it I would run a powerglide with a 4000-4500 stall. This way you only have one shift to mess up.
Consult the converter manufacturer before purchasing. Continental,ATI,Turbo Action,Hughes,Precision ETC. Take your pick.
I'd probably go with a Continental because they seem to have a better feel for what Pontiac motors like.
Bartman
Ponies run but Birds fly
Old 03-04-2003, 05:17 PM
Torment's Avatar
Torment Torment is offline
TH400 w/8" ATI for racing. They're 'streetable' but not the nicest deal for cruising. Sorry to hear they've been difficult as of late they're usually pretty sharp.
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 03-04-2003, 05:37 PM
dammen8's Avatar
dammen8 dammen8 is offline
I am going with a dynamic converter this time. They have come very highly recommended by my stocker friend, so I called them and they are very very friendly to talk to. I also do have another friend that is running one of their 8" TC and he is very happy with it, so I guess I will give them a shot. One thing that did help my decision was the list of stockers and super stockers that are running dynamic converters and winning, Al Corda is one of them and is also the winnings stocker of all time (I believe). So here is the website so you can check them out if you like.
http://www.dynamicconverters.com/
Chad Dammen
ND's fastest Pontiac (I think) and Minot's fastest street car (not like that means much)
3500lb 10.5" tire. [email protected] with a poor 60'
Old 03-04-2003, 08:52 PM
TTS's Avatar
TTS TTS is offline
A 350 will handle that job with no problem. A 700 would too. If you plan on really street driving the 700 would be hard to beat. 2.87:1 final drive
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson
"If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Right and wrong doesn't need facts all the time.
-Lighthouseman ("lawyer")
Starnes Performance Automatics
www.Starnesperformance.com
Old 03-04-2003, 10:04 PM
63Longtop's Avatar
63Longtop 63Longtop is offline
I run a powerglide with a universal case. My car weighs 3175 with driver. They are cheap to build, they are 40lbs lighter than a th350 and take take less hp to turn one. I had problems breaking the hardened race in my th350.
Old 03-05-2003, 05:00 AM
Thanks again guys I'm gonna call ATI today and see what they have to say,I may call Dynamic as well.Hopefully one of them can set me up with something..I appreciate the help
Later Rob.
Old 03-05-2003, 03:23 PM
TTS's Avatar
TTS TTS is offline
Jim, or anyone who has had 350 sprag problems, the hardened (black) aftermarket races are not worth the metal they are made of. If a 350 is built on a budget the stock race, in good shape, is worth 3 black ones.
The aftermarket drums available from Transmission Speciaties, or TCI are the only way to go when reliability is important.
The stock sprag outer race doesn't need to be hardened. It needs more contact than the 8 small rollers can supply. The race flexes because of the long distance between the rollers. The black race breaks because it cannot flex. The stock race breaks because it flexes beyond it's capability usually more than once.
Old 03-12-2003, 10:48 PM
tininjun67's Avatar
tininjun67 tininjun67 is offline
My GTO weighs 3250 with me in it. (close to yours)
I'm currently running a 406. I also run a 4.10 gear with a 29" tire. The trans is a TH400 with a TCI super competition 10" converter. The advertised stall speed was 3000. It actually pulls to 4400 with slicks on the car. Hello 60ft times! 1.56 is the best so far. I shift at 5800 and go through the traps at 6200 roughly. Best et so far is an 11.40 at 114mph. I wouldn't trade the converter for anything. It will not creep however, in fact, a little throttle is required to get the car to move. Our motors are similar, however, you've got more compression. Whereas my cam is a little bigger and heads flow a little more? 597/607, 249/252, stock E-heads, 10.25:1. Your car should easily run the same # as mine, if not quicker as I was struggling with a bad off the line bog. Good luck!
