My tach in my 66 GTO doesn't work. It worked 2 times in the past year for 15 seconds after I started it. Any suggestions? Also, can I remove this from under the dash?
66 GTO Conv Tripower 4 spd stock 67 GTO HDTP 400 auto stock 70 Judge 400 RAIII 4 sd stock original 69 Firebird 468 auto 28 option 49 F1 302 aod |
Ref.your tach problem.Try the nice people at [email protected] seem to know the most about tachs and instruments in general.I had very good dealings with them.Good luck and happy motoring. J.Tary
The tach cannot be removed unless you take out the entire dash bezel and remove the cluster off of the back of your bezel. The tach can be repaired as they will go bad from age and not necessarily from use.
------------------ Peter Serio Owner, Precision Pontiac
