Old 03-13-2003, 02:17 PM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
My wipers only work in mist mode. I changed the switch am now thinking it must be the wiper motor itself. Has anybody else experienced this problem ? Thanks to performance years for the catalog. I ordered parts today from it today to get my horn working . Thank you lord for performance years . Electrical problems grrrrrrrr
Scott
If you always do what you always did
You always get what you always got
Scott
Old 03-13-2003, 08:42 PM
68CONV400 68CONV400 is offline
If I re-call the wiper motor is two speed.On the very top of the assembly under the hood should be 3 connections.Low speed,High Speed,Common.
Use a VOM (volt/ohm meter) and check between the low to common,then the high to common on the motor itself.Both shoud give a resitance reading (but not the same with each-other) If either reads 0 or OL,it means that the winding for that speed is open.
If you don't have a meter.Run a jumper wire from 12v Pos side of the battery to your Low connection on the wiper motor,also run a jumper from the Common side of the wiper motor to either ground or the point on the connector that coinsides with Common. The motor SHOULD run.
Do this for both speeds.
Hope this helps,
Charlie
Charlie
