Old 07-19-2005, 10:55 AM
djohan djohan is offline
My '67 Lemans came with a chev 350 and 4-speed trans installed. I have picked up the power steering parts including the pump but do not have the bracket needed to install the pump to the motor. I have no parts manuals for the 350, so if anyone out there has a spare bracket that I can buy or has the part number of the bracket that I need, I would appreciate the help.
thanks...
Denny
Old 07-19-2005, 03:55 PM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Do you have the long or short style water pump. Also if I remember correct there are a few different style brackets with the long water pump. If you could post a pic that would help. BTW if you let me know I may be able to supply what you need.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 08-23-2005, 02:34 PM
bullheimer's Avatar
bullheimer bullheimer is offline
THat's true, your bracket will depend on the pump. i went thru like three before i found the right one, it is very frustrating.
I no longer have that beautiful 66 in my Avatar. whaaa!
When a cat is dropped it always lands on its feet. When buttered toast is dropped it always lands with the buttered side facing down. If a piece of buttered toast was attached to the back of a cat, when dropped, the cat/buttered toast combination should hover, spinning just above the ground, as it tries unsuccessfully to resolve the inevitable conflict of non-scientific certainties.
Old 08-26-2005, 04:05 PM
engineer engineer is offline
go to chevy online vendors to see their catalogs and illustrations for the correct bracket, then buy it.
