Old 08-11-2005, 10:58 PM
74Grandville 74Grandville is offline
Default 301 upgrades
I have a daily driver 79 firebird. I have been tuning the motor over the past couple months and it runs pretty good now for a 301 with 2.56 rear. I plan on changing to an 066 cam and a 4 barrel intake i've been working on. has anyone tried this? how does an 066 feel in a 301. I hope not to loose a lot of low end with the big gear, but hope to gain more power.
in the future I plan to put in a 200R4 with a 3.23 gear.
tell me what you think.
Jason
Old 08-24-2005, 10:22 PM
I plan to do the upgrade of the cam and intake this weekend. currently i'm getting an average of 19mpg before the upgrade. i'll let you all know what I think of the upgrade after i'm finished.
Old 08-25-2005, 01:56 AM
heff heff is offline
what kind of intake are you working on? 066 is probably about as much cam as a stock 301 can handle. and it's that big of a cam. intake and exhaust ports on 301 heads are tiny little things, as are the valves. if it works out good for you, let me know. i've got another GP with a 301 i wanna do some work to.
Old 08-25-2005, 05:04 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I would think porting the heck out of the intake and heads, a little more cam and more rear gears would be the best first stage. Those weird intake ports are a big restriction.
Old 08-26-2005, 12:15 AM
I am not an expert so this style of an intake might be worse then stock. I just did what I thought made sense as I do NOT have the correct spacer or carb for this intake. the secondaries on a normal q-jet seem to be bigger then this intake was made for. I have a 1inch spacer that I have sanded to give the correct placement for the carb. the second spacer is a 1/2 inch. I have not ported the intake as I didn't want to make the ports bigger then the head. I don't plan to take the heads off right now to do any work. this is just a fun project I came up with. it was cheap and that is all i can afford right now.
ID:	25643   Click image for larger version
ID:	25644   Click image for larger version
ID:	25645   Click image for larger version
Old 08-26-2005, 01:44 PM
Skip Fix's Avatar
I never understood the rationale of a single plane on a 301.
Old 08-28-2005, 11:43 PM
Well I didn't end up having time to change the cam in my firebird, but I did put the intake and carb on the car. supprisingly I did have a gain in power from 2600-4000. i'm happy with the upgrade. one thing I forgot, since I don't have the correct spacer for this intake I didn't have a place to hook up the PVC. I'll make a spot for it like the older intakes when I put the cam in the motor.
Old 09-05-2005, 03:07 PM
UnNova73 UnNova73 is offline
Jason:
I ported a set of turbo 301 heads, for a buddy of mine's N/A 301-powered 4-door '80 Bonneville. I must say: I have yet to see a set of heads with less counter-productive intake and exhaust port characteristics; nevermind the sizing of the intake and exhaust valves. I must have done something right, though, b/c even with a very mild Comp Cams grind and a VERY mild powertrain setup: The darned thing runs 14.4's; LOL.
Old 09-06-2005, 12:41 AM
Formula77 Formula77 is offline
Send a message via Yahoo to Formula77
The only real experince with 301s is in ripping them out of cars, (need a couple, I know where to find them pretty easy) it sounds like you have a pretty good handle on what you want to accomplish with your car, out of ceriousiy why are you sticking with the 301? In my oppinon it was the worst engine that pontiac ever put into a car, but once again, thats just me.
Pure Pontiac Excitment. There is no replacement for Displacement.
Old 09-07-2005, 10:31 PM
it what I have, and it's running well (53,000 miles). when I have more time and money I may build a 400 for it. I also may buy a stock 72 455 for it a friend has.
Old 09-12-2005, 12:46 AM
well I put the 066 cam in this weekend. i've decided 1.5 days is not long enough to do a cam swap. it wasn't fun rushing around. as for the performance. i'm sorry to say I wish I went bigger. maybe a summit 2800 would have been better. it does rev quicker and is more responsive. I'd say a little more power through out, but most of the gain was from 3000+
i'd say my next step is the exhaust and rear end. I have a 3.08 posi I may put in.
Old 03-28-2006, 12:47 PM
Default update 3/28/06
I'm still driving my firebird with 301 and i'm much happier now( 64,000 miles). I wanted to update everyone since this motor is forgotten by most. I found that I had an issue with my distributor and my valves were tighten down to much with the stock nutz. i've change my mind on the 066. I think it was a good choice for this setup. maybe an even better choice would have been a small XE comp cam to build compression since the 301 is 7.5:1.
i've done some transmisson upgrades that have seem to really help things. I changed the stall from the stock 1500 to 2100 with a B&M converter. i've also put a shift kit in and changed the governer to shift at 5,000 instead of 4,000. The motor runs pretty strong now begging me for 3.42 gears.
my car loves the highway, it still very slow from a start, but has good power from 2500-5000. I spend my time mashing the pedal at 35mph. first gear shifts around 65 and second is around 100.
I plan to put in the 3.42 gears in a couple months.
Old 04-06-2006, 10:11 AM
stu stu is offline
You will be very happy with the 3.42, I swapped to that ratio from a 2.73 and the effect was huge with the 301. I also ditched the stock exhaust and went to 2 1/4 dual system out the back with turbo mufflers. These two changes gave a big seat of the pants increase over the stock setup. I also used lighter springs on this mech. advance and am running 15 degrees of initial timing. Hard to crank when it's hot but gives the best power. The stock cam is 189 degrees duration at 0.050, 0.365 lift, what I think it needs is between 195 and 200 and mid 400s on lift. It is fatally easy to overcam this engine, I once installed a mild street cam in one and it was a total pig, by the time it came up on the cam the VE fell off from the teeny intake runners. This was with open manifolds, so there was not much restriction on the ex. side.
I would love to see what a highly tweaked 301 could do, it would never compete with anything else but would be unique.
Old 04-09-2006, 10:16 AM
Brian Baker's Avatar
Originally Posted by UnNova73
Jason:
Can you provide more specific details about the car and the whole combo? We've got a 301 discussion going on over at the CP board and I'm looking for all data on practical applications of the 301 that work.
Old 04-09-2006, 04:08 PM
MalteseFalcon's Avatar
MalteseFalcon MalteseFalcon is offline
Didn't Herb Adams use a 301 for the basis of the engine in the SilverBird? Bored and stroked to 6 litres, and with RAIV heads (modified the block so the water passages matched up), around 600 hp, as I recall. But that's pretty highly "tweaked"
Steve
1978 WS6 W72 4 Speed Trans Am - Martinique Blue on Light Blue - Fire Am Restification Project
1972 4-Speed 455 HO Trans Am - Original Cameo White on Blue car - Restoration Project
Old 04-10-2006, 03:28 PM
stu stu is offline
The "rules" would include using the stock heads. I didn't realize other Pontiac heads would bolt up, once you swap heads it's a different engine IMO.
Old 04-10-2006, 08:20 PM
My understanding (only from what I've read) is not that other Pontiac heads will just bolt up, but that they can be made to bolt up with mods to the block, which includes relocating water passages. I'll have to go and check my back issues. I am positive that the SilverBird used RA IV heads on a 366 CID engine. I have some issues of Fast Lines in which VSE was selling the heads.
Steve
Old 04-11-2006, 11:06 PM
Sigh...in a phrase, hell no. Herb did not use a 301 block in the Silverbird. Short deck it may have been (like a R.A. V 303 or 366 block), but it was not a 301.
Old 04-12-2006, 12:05 AM
This is from the 6 page article in the September 1978 issue of Road & Track on the Silverbird:
Name:	Road and TrackSept1978.jpg
Steve
Last edited by MalteseFalcon; 04-12-2006 at 12:25 AM. Reason: Remove snarky comment ;-)
Old 04-12-2006, 12:23 AM
Here's an ad from VSE's "Fast Lines" selling off the engines in October 1981. Can't really tell. Smaller version is a 309, not a 303.
I agree that a short-deck SCCA Trans Am engine makes more sense, perhaps even more so with Tom Nell building it. Probably the magazine got it wrong. Seems like a pretty big error in an otherwise thorough article, though.
Steve
