Old 08-25-2005, 12:18 PM
Formula400NYC Formula400NYC is offline
Default Door glass adjustment
How do I adjust the stops on the tracks? The glass goes up unevenly and the rear part goes up too much. Also where can I buy the felts that keep the glass from rattling around? I cant find it on PY's site?
Thanks....Jerry
Old 08-28-2005, 02:19 PM
Anyone, this driving me nuts.
Old 08-28-2005, 05:06 PM
Superduty65's Avatar
Superduty65 Superduty65 is offline
I'll look at mine and let you know what I find. I am restoring mine and had all the glass out. I just re-installed all the glass but did not run into a problem other than getting the rubber glass gaskets to stay put while I re-installed the bolts through the glass. My windows go up evenly but I cannot get my quarter windows to allign correctly. The chrome glass frames are tilted towards the front of the car some and create a bad seal with the side window so I am working on that issue. I will look and let you know what I find out.
Semper Fidelis
Old 08-29-2005, 08:28 AM
Frank'73 T/A's Avatar
Frank'73 T/A Frank'73 T/A is offline
Default Felts
Jerry, Classic industries has the Inner door panel retainer plates you are looking for. There are 2 different sizes per door. It is listed under interior components.
28 years ago, my dad said to my worried mom, "Don't worry he'll outgrow this trans am phase"
Old 09-01-2005, 07:33 PM
Resto70 Resto70 is offline
Jerry, there are 2 stops, front and rear on the vertical guides. The bolt screws into a metal pad that fits into the guide, the pad stops the window roller. Loosen the bolt and set it higher or lower for more or less up travel. Hope that makes sense, on the felts are you asking about the felt pad (3/4 or 1 inch across) that bolts to the door or the full length window seal on both sides of the door glass?
Old 09-03-2005, 07:05 AM
Thanks Resto, thats what I was hoping to hear...
