Old 08-25-2005, 03:04 PM
gotpontiac gotpontiac is offline
Default 1986 fiero gt auto- trans swap.
I want to know if I can swap a 4t60e/4t65e for the c-125 that is in the car?
Wil it bolt up to the 2.8L v6?
Will it work with the factory ECM?
Do they mount in the frame the same?
I can make any kind of mounts that I might need.
The motor needs to come out for a rebuild,
and I want to up the trans as well.
Or maybe a 3.4 and trans swap.
Greg
1969 Firebird/400/th400/3.42:1 rear
1/4=? MPH=? (WIP)
1983 1/2 ton Silverado/lwb/305 (89 FB)/
MSD ign/Mallery coil/83 intake/
700-r4(rebuilt w/shift kit and corvette servo)/
3.73 gears/31x10x15 all terrains.
10.9 1/8 mile. 17.xx 1/4 mile
1996 C2500/6.5L TD/4L80e(shift improved),4" exhaust
cold air intake, mechanical WG controller
3.73 gears/265-75-16 w/Eagle allows.
2002 1500 Suburban/stock
1986 Fiero GT,needs engine.
Old 08-30-2005, 08:17 PM
Oreif's Avatar
Oreif Oreif is offline
If I remember correctly you can use the non-"E" trans. The 4T60 is a common swap. Most use the 4T65e when they do a 3800/3800SC swap because the ECM/ECU has the electric control for the trans.
Happiness isn't around the corner...
Happiness IS the corner.
1986 Fiero SE
Now ZZ4 Powered!
Old 09-02-2005, 08:00 AM
Default THANKS,
Would it be worth while to rebuild the 2.8L or find a 3.4 to swap in?
The car is for my son(15yrs old) to drive when he gets his license.
The car is in real good shape,just needs a new engine.
Greg
1/4=? MPH=? (WIP)
Old 09-04-2005, 08:58 PM
Oreif's Avatar
The 3.4L swap would be better as the block has better oil galley's. It uses the same external parts as the 2.8L so it will look stock.
If you are interested in doing the 3.4L swap, Here is a very good website with detailed instructions for doing the swap.
http://www.eleventenths.org/fiero34project/
1986 Fiero SE
Now ZZ4 Powered!
