Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 09-01-2005, 07:51 PM
Hitman's Avatar
Hitman Hitman is offline
Default Need a shop in Metro Atlanta.
I need a alignment, tires flipped around remounted and balanced, pinion seal replaced, trans pan gasket, and a shift linkage gasket replaced and also someone to set the timing and adjust the carb. I would like someone who works on our old cars that knows them well, or if any of you PY'ers and fellow Pontiac lovers are near and want to earn a few bucks, let me know. I have a 67 Lemans with a 72 Model 400, with a edelbrock 4bbl carb and HEI ignition. Thanks for your help here.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
Old 09-01-2005, 10:30 PM
goatseeker's Avatar
goatseeker goatseeker is offline
Hitman,
As far as alignment and tire work - there is a guy named Neal (Neil?) at the Butler Tire in Marietta has done my alignment twice. He respects and understands musclecars and I'd highly recommend him. All my rear end work goes to Southern Gear in Smyrna - but you have to bring them the tranny or rear end out of the car. If you don't mind getting dirty the other stuff can be done in the driveway with a couple wrenches and maybe a screwdriver.
If you want to have someone work on everything else except the tires, I'd recommend Jeff Ianitello at Engineered Performance in Smyrna. Good guy & Pontiac nut.
Tim
Old 09-02-2005, 06:33 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
Originally Posted by goatseeker
Hitman,
Tim
Hitman I second Goatseeker's motion. Jeff will take good care of you. Here is his web site.
http://www.engineered.net/
Easy to get to @ the I-285, Hwy 41 exit, (Cumberland Mall)
Less said,,,,,,,, Less mended.
Smilies are Off
