Old 09-07-2005, 02:04 PM
big bee big bee is offline
Cool American model vrs Canadian
I am looking at buying a 1955 pontiac 2dr station wagon.Im told it is an American model,is there a differance ? woll the motor tranny ect be the same.Ithink some of the molding on the outside is different. Please help this mystified Canadian
Old 09-07-2005, 02:49 PM
Bad Karma's Avatar
Bad Karma Bad Karma is offline
IIRC The canadian Ponchos came with Chebby engines BUT Its only what I have learned from here. I have no documentation to back this. Someone with more background on the subject might chime in.
72 Lemans
Old 09-07-2005, 03:16 PM
Ron H's Avatar
Ron H Ron H is offline
The 68 firebird I own was bought in Canada with a poncho 350.
Old 09-07-2005, 03:36 PM
rowling rowling is offline
I know the Beaumonts were essentially a Chevelle with a GTO interior, a chevy drive train and different badging. (on the 65's anyway). I don't know the differences in the 55's though.There are a number of Canadian Pontiac sites that could help you out if you have a few minutes to surf.
Good Luck
Glen.
Old 09-07-2005, 03:39 PM
Stuart's Avatar
Stuart Stuart is offline
Full size and intermediate size Pontiacs sold in Canada as new cars in the 1950s and 1960s used Chevy frames, suspensions and engines. I believe many of the cars sold in England and Australia were the same deal. So, if the car you're looking at has a straight 6 or 265ci Chevy engine, it's a Canadian car. If it has a 287ci Pontiac engine, it's a US car. If you see a '59 or '60 Canadian Pontiac, for instance, it's very apparent as they don't have the Wide-Track stance of a US car.
There's some more information available on Canadian Pontiacs at http://www.canadianpontiac.ca/
or http://www.bruneauperformance.ca/intro.html
Old 09-07-2005, 06:00 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
For starters, all the frame,suspension and brakes are differant as noted, Pontiac used 122" or 124" wheelbase, the Chevy/ Canadian Pontiac use a 115"WB. 5x5 wheel bolt pattern for Pontiac, 4 3/4 for Chevy/Canadian. At least with the Chevy frame/suspension you can buy any aftermarket brake /suspension upgrade available.
I would think the moulding at least for the rear would be shorter because of the shorter wheelbase? The doors / trim are the same as well as the glass.
Old 09-08-2005, 07:49 AM
Ron H's Avatar
Is a Beaumont a Pontiac? I always thought it was a Canadian chevy chevelle. Interesting to learn the way they built them in those years. I guess because of where the plants were and tariffs.
Old 09-08-2005, 08:21 AM
PLAY400's Avatar
PLAY400 PLAY400 is offline
Firewall is also different between the Canadian and American Pontiacs due to the different stagger of the heads between the Chebbie and Pontiac engines. I had a bugger of a time putting a Pontiac motor in my 55 Canadian Pontiac so I figure a Chebbie in an American one would also be a nightmare. Steering boxes are in different locations as is the Master cylinder and heater assembly. Frames are completely different. Alan
Beaumont is a Pontiac. Used to be know as an Acadian Beaumont. Exact clone of a Chevelle except instead of the Super Sports (SS) model they had a Sport Deluxe (SD) if not mistaken. Chevy power. Made only in Canada. Super rare and extremely desirable and expensive
Old 09-08-2005, 11:42 PM
cvs cvs is offline
This is a Beaumont: (click to enlarge if this works!)
Chevelle sheet metal, frame, powertrain, seats, door panels.
GTO dash.
Unique grille, tail lights, emblems.
Ignore the wheels, they are Buick.
Carl
Old 09-09-2005, 07:23 PM
Bad Karma's Avatar
Supposedly It bolts right up in the 70 to 72 GTO. I think you have to move the tranny crossmember up to the next set of holes. The radiator holes may not line up. The power steering needs just a piece of rubber hose for the return line to get it to work.
72 Lemans
