Old 09-13-2005, 09:20 AM
68blkbrd's Avatar
68blkbrd 68blkbrd is offline
Default Finding Base Circle of Cam
I am adjusting my valves soon on my .030 over 400. I have HS 1.5 roller rockers, Comp Cam 292 Magnum Hydraulic Camshaft and lifters, #13 heads milled .010. and stock length 5/16" pushrods.
I am going to use the Pontiac Street Performance method of adjusting with engine off. I am doing this with the manifold on and valve covers off.
I am locating TDC with finger in spark plug hole and feeling compression stroke. How do I know that I am on the BASE circle of the cam when adjusting? Does it need to be exactly on the base?
Any help is greatly appreciated. Thanks!
Old 09-13-2005, 09:28 AM
quick67bird's Avatar
quick67bird quick67bird is offline
This site might help you 68blkbrd. I followed these steps and although it took some time my car ran great. With the car on top dead center this method will help you find the base circle.
http://www.angelfire.com/fl4/pontiac.../valveadj.html
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 09-13-2005, 07:06 PM
Will Will is offline
A foolproof method is as follows:
For each pair of valves on an individual cylinder - rotate engine until intake valve closes. Adjust exhaust valve. Rotate engine more until exhaust valve just begins to open. Adjust intake valve.
