Old 09-13-2005, 04:14 PM
DADZZ64's Avatar
DADZZ64 DADZZ64 is offline
Smile Heads
Ok i need some info guys right now i have a 455 with 4x 1H heads on it and i have a chance to get a set of 74 350 GTO # 46 494346 Screw 2.11 1.66 89 will this give me better performance then the stock 455 4x 1H heads ???
Old 09-13-2005, 04:25 PM
Kenth's Avatar
Kenth Kenth is online now
Replacing your 114cc heads with a pair of 89cc heads will give better performance for sure..........grab´em.
Old 09-13-2005, 04:42 PM
76 Badbird 76 Badbird is offline
You will need to watch the rest of your build to make sure the comp ratio does not go too high if you want to run pump gas.
Old 09-13-2005, 04:57 PM
77TA406 77TA406 is offline
I have a set of these heads as well...but I thought the valves were 1.96\1.66. With the small chambers, I always thought they might be a good head to port and use on my 406.
Chris
Old 09-13-2005, 07:10 PM
Will Will is offline
Definitely double check that valve size as I too thought they were small valves. Still, the chamber size is much more favorable and adding larger valves isn't a problem.
Old 09-13-2005, 08:45 PM
DADZZ64's Avatar
Thumbs up
Thanks for the info guys i am going to grab on to them here is a link to a pontiac site with head id and stuff from 1959 to 1981 thats where i got the info on these heads and it shows in 1974 2 sets of #46 heads one set with the bigger valves 2.11 1.66 89 volume and the other set with smaller valves 1.96 1.66 ...98 volume take a look http://www.angelfire.com/on/geebjen/heads.html
