Old 10-05-2005, 05:44 PM
Geeto 67 Geeto 67 is offline
Default ignition timing questions?
Hey gang,
I posted this question in another thread as part of a few. I haevn't gotten an answer on it yet so I thought I would ask here:
What is the ignition timing specs on a stock 1967 335hp GTO 400? the initial (I think 6)? The mech advance? the total advance? is it any different for a HO or Ram Air I engine?
What is the ignition timing specs on a Ram air IV cam?
What is the best way to time the engine (start with the total first? the Mech first? or the initial first?).
Thanks,
Kerry
Old 10-05-2005, 06:07 PM
Jeff Hamlin's Avatar
This should help...
Old 10-05-2005, 06:16 PM
that's awsome, where did you find it? Any chace there is a bigger version out there (kinda hard to read on my small screen).
Old 10-05-2005, 07:27 PM
Right click and save as, Then open on your end in any photo file/program to enlarge.
If unable to do so I'll glady email a larger file to you.
Old 10-05-2005, 09:04 PM
Took it inot photoshop and blew it up some of it is readable but too pixelated to read all of it.
Please e-mail me the larger file at Dean_morarity@yahoo.com (there is an underscore between dean and morarity). It looks like it was page sized 8.5 x 11 if you can get ti to that size It will be great b/c then I'll print it out.
Old 10-06-2005, 07:02 AM
email sent.
Cheers
Old 10-06-2005, 09:56 AM
Teej's Avatar
Teej Teej is offline
Jeff, Any chance I could get a copy of that? I had the same problem.. Cool stuff
Thanks thad.w.johnson@nasa.gov
Thad
1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver
1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!!
Old 10-06-2005, 10:20 AM
ctgross ctgross is offline
Smile
Jeff, me too if you don't mind. That would be a good addition to any shop material. Thanks,
ctgross@msn.com
CT Gross---66 GTO
"Its never too late to have a happy childhood"!
I told my dad I was going to stop raising hell, and he called me a quitter!
Old 10-06-2005, 11:59 AM
GeeTeeOhh's Avatar
GeeTeeOhh GeeTeeOhh is offline
Good info. I too would like the larger file. g6t6o@cableone.net
I or someone else maybe could post it to their website for the rest of us to download.
Old 10-06-2005, 07:31 PM
Done...
Old 10-10-2005, 10:51 PM
jhfaust's Avatar
jhfaust jhfaust is offline
Default '67 specs sheet
Jeff, did you post a larger version of the sheet? If not could you please email me a copy when you get time? Thanks, Jim.
Old 10-11-2005, 11:02 AM
oz07 oz07 is offline
Default Great Information - Did someone post the larger file?
I'd like to have a copy as well. Did anyone post the larger file? e8594@aol.com Thanks
Old 10-11-2005, 01:28 PM
67TIGER's Avatar
67TIGER 67TIGER is offline
Same here!
thudbuddies@aol.com
Thanks!!
1967 Pontiac GTO
1965 Olds Cutlass
2014 Ford Mustang
GTO-The Great One for 1967
Old 10-11-2005, 01:49 PM
Thanks to Jeff for the old Sun distributor cards which I though would be lost forever.
To rehash my problem here it goes:
Saturday I set my timing. I did it first by disconnecting the vacume advance and setting the timing at 23 degrees. Connected the vacume advance and got 45 degrees total. Then I had my gf stand ont eh brake with the car in gear while I set the idle to 600 rpm and the timing came up 6 degrees (with the vacume advance disconnected). Fuel pressure was 5.5 psi at 1000 rpm. Looked like everything checked out until she put it in park. Now the car idles in park at 1500 rpm (WTF!) and when I go to shut it off it diesels. Also when I get on it I get a backfire through the secondaries.
Ok what did I screw up? The whole reason I was trying to set the timing in the first palce was because the car was diesling when I shut it off. Now it is worse than ever. HELP.
Old 10-11-2005, 02:57 PM
tom s tom s is offline
you set the initial at 23?Dont think mine would start with that much!
Old 10-11-2005, 03:37 PM
Kenth's Avatar
Kenth Kenth is offline
I think you have a lean condition due to either vacuumleak (bad flange gasket/cracked hose/s?) or clogged ilde circuit/misadjusted idle screws or a hotter than standard camshaft ( over 225 degrees @ .050").
Check vacuum in manifold with vacuum gauge.
Initial timing is usually set at idle speed, you may check the advance at 2500rpmīs though.
Old 10-11-2005, 05:31 PM
No I set the mechanical advance at 23 degrees (rev to 3000 rpm and disconnected the vacume hose). I did this first since the initial problem that caused me to mess with the timing in the first place was a secondary backfire because the distributor walked.
The cam is definalty a hotter cam, but I have no specs on it and I don't want to tear the engine down.
Don't know if the flange gasket is any good or not (the carb hasn't been off the manifold in seven years) but all the hoses look tip top. I am adjusting the throttle stop for the idle so it is possible the carb may need a teardown. Where would I hook up a vacuum gauge to check manifold pressure?
About the idle speed. do you set initial timing with the car idling in gear (D) or in park? I set the idle speed with the car in gear and then checked the initial timing. Should I re do it?
Originally I put the car in park and set the idle at 600, set the timing at 6 degrees initial, and then revved it up to take a reading on the mech advanced and total, I got 37 degrees mechanical advance and 50+ degrees total. That is why I decided to set the mechanical first and adjust the idle to compensate.
Old 10-11-2005, 06:30 PM
Junkyard Dog's Avatar
23 degrees is nowhere near enough at 3000 rpm. Where are you getting your procedures?
Set the initial timing in Park, with the vacuum line disconnected, and with the vacuum leak plugged, of course. You are going to have to adjust your idle speed back down, and readjust it if moving the timing moves the idle speed, then recheck the tiiming.
It sounds like you "originally" (your last paragraph) did it correctly. Do it that way again . . .
Dieseling can be something as simple as not enough octane for the car. My GTO would diesel with 87 or 89, but not with 93 octane gas. If your engine is still original, you may be pushing it on pump gas anyway . . .
If memory serves, that engine was rated at 10.75 to 1 compression (someone will correct me if I got it wrong) and really works out to 10.25 to 1, which is still pretty high for iron heads.
Badder than old King Kong
-Jim Croce
Old 10-11-2005, 09:24 PM
Perses's Avatar
Perses Perses is offline
I'm curious what the connection is between Sun Electric Corporation and Pontiac ?
Old 10-11-2005, 10:58 PM
Sun electric made the sun machines which allowed shops to test and "tune" (recurve) distributors. If you owned a car in the 1950's through the 1980's and had a shop work on it, at some point the distributor passed through a sun machine. They are a rare thing to see in a shop these days and recurving a distributor is a dying art.
Sun would get the maufacturer's specs and print them on cards. A mechanic would take the distributor off the car put it in the sun machine, and the sun machine would spin the distributor so you could check it at various rpm levels. Depending on the machine it could also give you readouts of certain information, set the advance, and tune the weights. The cards allowed you to "blueprint" the distributor according to the manufacturer's specs. I used to have a binder with a ton of old sun cards in it but it was destoryed in a basement flood (raw sewage otherwise I would have kept it).
The motor was rebuilt 5000 miles ago. It has 9.5 to 1 compression and used to run really sweet off 93 octane. When the motor was new the car was really fast (high 12's on slicks). I'm going to redo the timing, and yes the idle moves when you move the timing.
I am slowly coming to the realization that there is a distributor rebuild and a carb rebuild in my future.
