Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 10-21-2005, 04:56 PM
68MeanVerdoroGreen's Avatar
68MeanVerdoroGreen 68MeanVerdoroGreen is offline
Default Keisler Engineering 5 Speed Transmission Kit
Fellow forum members,
Has anyone puchased or have information on Keisler Engineering.
This looks like a nice complete package that puts the stick shift in the original place and work with the stock crossmember.
http://www.keislerauto.com/gm/transm...elle_68-72.asp
This would make a good project for me over the winter.
Thanks in advance,
Larry Metzger
Columbus, NJ
1968 GTO Verdoro Green Hardtop
1969 GTO Palladium Silver Hardtop
1969 Judge Carousel Red Hardtop X 2
Someday We'll Look Back On This And It Will All Seem Funny.
From Rosilitia, Sung By Bruce Springsteen, CIRCA 1973
Old 10-21-2005, 05:37 PM
black_bird's Avatar
black_bird black_bird is offline
I did the swap in my 81 Trans Am, and I like it now. When we ordered the kit we had some issues getting parts from them; it took quite a while, but it was worth it I think in the end. There are some other companies out there I believe doing this swap now, and I've seen a couple with a different shifter setup that I think work better than the way Keisler did mine. I'm happy I did the swap, first gear is wicked, and having an overdrive is so nice. It also looks pretty dang stock on the inside. The shifter I got looks nothing like the one in the picture, and we had to have a new crossmember made, which they supplied in the kit. So, I imagine a few things have changed since I got mine. I think you'll likely enjoy the overdrive when/if you get it; it's so nice on the highway. I think I've rambled on enough now, lol, any questions, hit me up. I can take pictures or whatever if you want me to.
Old 10-21-2005, 07:11 PM
berrygoat's Avatar
berrygoat berrygoat is offline
Do a search under the member "streetking". He had the same deal with pic's in an old post.
Old 10-21-2005, 09:18 PM
Silver Judge's Avatar
It's easy to be interested in TKO 600 conversions for obvious reasons.
I notice that this Keisler website has no detailed info on floor plan sheet metal mods which are part of one of their kits, that makes me wonder.
Others on this forum have basically done their own metal fab to cover the enlarged opening you need to make in the floor but if a kit makes it easier and less time consuming than it could be really great.
Some of the kit details indicate that they come with a hi performance clutch,
I would personally prefer to select my own clutches and know what I'm getting.
Let us know what you find out, this is a good subject :cool:
501 HP, 554 ft lbs TQ
Old 10-22-2005, 03:04 PM
Hammered's Avatar
Hammered Hammered is offline
I bought the Keisler kit for my '67 Firebird and they are terrible to deal with. Don't believe Keisler's advertising. My complete, no-cut kit was not complete and required cutting. They sold me a Chevy pilot bearing (which they stuck me with) and almost sold me a driveshaft for the smaller Chevy u-joint. As soon as they had my money, there was no talking to them again. If you think my experience was unique, go to some of the Chevy boards and ask this question-you will get a similar response to mine. The TKO is a great upgrade, but I strongly suggest you go with another vendor like http://www.classicchevy5speed.com/
1967 Firebird Convertible Factory 400/4spd
Now 462/5spd Fuel Injected
http://1967firebird.atwebpages.com/
Old 10-22-2005, 05:00 PM
400 4spd.'s Avatar
I have done a Keisler kit on a customer's car (Barracuda), and it was not a smooth ordeal. First, there was a 6 week back order that turned into more like 4 months. They supplied the wrong hydraulic cylinder, and omitted some of the installation instructions. The template for the floor brace cut out was off by an inch. I found that when the engine/trans assembly was put into place.
Phone contact was a PITA, because most of the time the phone went unanswered.
I have read only positive things about Classic Chevy, so I would lean in that direction next time.
Old 10-24-2005, 12:11 PM
HWYSTR455's Avatar
You guys are scaring me! I just got my TKO 600 kit for my '71 T/A, and am just getting ready to get into it.
Already noticed the pilot bushing/bearing thing, was for a Chevy, figured as much though, and not too upset over eating that.
BLACK_BIRD: You say you had issues with the cross member? Do you recall what those were? Maybe I can head that off at the pass... Also, you mention that others make better shifters? Can you give me a source? Is there an issue with the one that came with the kit?
HAMMERED: Guess I need to be careful when I order the driveshaft then, huh? Is it going to matter if I give them complete details (9", etc), or are they going to get it wrong anyway?
Old 10-24-2005, 12:20 PM
black_bird's Avatar
Let's see. The shifter I have is a sort of "custom" design I guess. It's kind of cut into the side of the tail housing, where as a normal/stock shifter for this transmission should sit on top of one the towers. I saw in a post here, about the Classic Chevy kit, they had an off-set shifter, that mounted like a normal one, but was made in such a way that it would mount/look stock inside the car.
The crossmember problem I believe was taken care of, the issue was, they didn't even have one ready to make/send out. So, we took measurements of where it would need to be and such, and told them over the phone. Then we had to wait an extra couple of months for it. It fit ok once we got it, one of the only things that fit right.
I also had a problem with backorder, I was qouted around 6 weeks, and once it was all said and done, it took 10 months to get everything to me and be ready to install. I'm not even kidding. I didn't want to sound down on them in my first post, I've heard of a few good stories about them, but my experiences pretty well agree with what everyone else is saying. Like I said, it worked fine once we got it in, just getting it in, and dealing with them, was somewhat of a pain.
Old 10-24-2005, 11:16 PM
Hammered's Avatar
HWYSTR,
I had to argue with them for more their a month over the drive shaft! The problem was that they my money or I would have gone to someone else. The only reason I caught their error is that they wanted me to upgrade to a 1350. They would not believe that the BOP 8.2 rear is different from the Chevy. Once they were convinced they said that their driveline shop couldn't make a drive shaft with the correct yolk. I finally gave up arguing and told them to send the correct shaft or I would be contacting VISA to cancel the whole purchase. Suddenly they could make my shaft although it was about 10 weeks late. So the short answer is go to someone else.
John
Old 10-25-2005, 12:28 AM
black_bird's Avatar
HWYSTR,
John
We had a couple similar run-ins with them, that once we wanted to cancel and go somewhere else, they could all of a sudden make the part or do whatever. They couldn't seem to get the driveshaft right for me either, as I recall, we had to have one made local, and they did refund us that cost, which suprised me. I dunno, I'd definitely see what else is out there before you jumped into it, I certainly would if I were to do it over again.
Old 10-25-2005, 06:26 AM
HWYSTR455's Avatar
Great. Well, live and learn, and guess I'll see how it turns out, since I'm kind of not in a position to turn back! I actually purchased the kit in like Nov/Feb, and drop down there to pick it up. Had a 3550 conversion from Forte, but the 600s came out, wanted one of those. They did buy my 3550, though I took a beating on it (think they gave me a grand for it).
Anyway, I'm not waiting 10 months or even 10 weeks for a drivesahft, I'll go to dutchman or something and get it in a week. Might have to eat that one too...
As for the shifter, I'll just have to see how it works. If it doesn't work as I hope, then I'll look into the classic chevy one. I did check that out on their' site, and it does look nice. I'm concerned on the Keisler shift when power shifting or whatever, the arms/rails may bow, not giving a clean shift. Again, guess I'll see!
Darn! And I was really interested in the hydrastic throw out bearing wetup they have! I called yesterday and they said there was a backorder on the masters, and it would be a couple weeks. Wonder if that's the 'common' response. Might have to roll the dice there too....
Old 10-25-2005, 06:27 AM
HWYSTR455's Avatar
Oh, one more thing, drove the wife's new (at the time) Marauder down there and got a healthy ticket on the way. Maybe I should have turned back then!
Old 10-25-2005, 09:13 PM
Hammered's Avatar
HWYSTR455: I hate to ruin your day even more, but you can't mount an aftermarket shifter on the Keisler TKO. Another thing they don't tell you is that they mill about 0.1 to 0.2" off the top of the mating surface on the trans so only their shifter will work. Perhaps you could make a spacer or replace the tail cone-not sure.
Old 10-25-2005, 09:52 PM
HWYSTR455's Avatar
Great. Well, guess I'll cross my fingers on shift quality then!
Old 10-26-2005, 11:26 AM
black_bird's Avatar
Well, like I say, it works ok once you get it all in. I've beat the crap out of mine, and it keeps on ticking. Power shifting, missing shifts, normal, clutch drops, you name it, lol. I've dropped it at 3500 on slicks at the track, then power shifted it all the way down. I'm not making huge power or anything, but it holds up. It's only ever not shifted good once or twice, and I think most of that is my clutch. I think the main problem with them, is their customer service and willingness to help a guy out.
Old 10-26-2005, 11:45 AM
6567GTO's Avatar
6567GTO 6567GTO is offline
When I called Keisler they told me that I'd have to wait 6-8 weeks for a TKO-600. I had heard that they were slow on getting parts out to people. I ended up going with Classic Chevy 5 Speeds and was very happy with their service. I received my trans in 5 days with all the correct parts. I have one of their offset shifters and like it very much. They even contacted me later on telling me that one failed for a customer and that they'd be happy to send me a newer version before I had any problems. Great service from Classic!!!
_________________________
Sonny Barger
Old 11-12-2005, 06:47 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
Expect lots of modifications. My friend is putting one in his 69 GTO along with full Hotchkiss suspension. They are still not 100% done with the install and have been on the phone with Keisler for months. They got it right for the Chevelles, but the Pontiacs use a different shifter and opening so there was a learning curve for everyone here. I'd expect some changes from Keisler on the GTO kits after this fiasco is cleared up. Don't have any pics but can give more info if anyone wants it.
John
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 11-17-2005, 03:22 AM
jeffmort jeffmort is offline
Everyone-
Thanks for the kind words. We are doing are best for the Pontiac guys! Regardless of who you purchased your TKO from, feel free to give us a call if you have any questions or issues and we would be glad to help.
The McLeod shifter is getting great feedback - we have delivered a bunch of them and the response has been very positive.
We now have a tunnel patch for the GTO's to help the install go a bit smoother.
Check here for one of your fellow GTO buddy's (Alex Godsey) nstallation write up - he did a great job: http://www.classicchevy5speed.com/tr...967_gto_wu.htm.
Jeff Mortenson
Hurst Driveline Conversions
www.hurst-drivelines.com
760-438-2244 (ext. 103)
[email protected]
"Specializing in Tremec TKO & T56 Magnum overdrive conversion kits for Pontiacs"
"Number 1 in Customer Service & Support!"
Old 11-17-2005, 06:27 AM
taalltheway taalltheway is offline
Is Keisler really that bad? I have read from a lot of post here that people were happy with Keisler - not to mention Rocky Rotella´s report in HPP. Maybe their internal structures and organization was not up to the big demand....happens a lot of time...
i am also thinking about buying a kit and since i am in Germany i would be really afraid to get wrong parts and try to solve this with a company that is in a very different timezone...
Does the Classic-5-speed also require no cutting? Is it a simple bolt in? Do their Tremec 500s also sport the lower first gear? Do they ship to Germany?
Old 11-17-2005, 09:25 AM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
I have to give a thumbs up to the guys from Classic Chevy 5-Speed. We are finishing installation of a TKO-600 in a '66 GTO Convertible. Tunnel modifications were fairly extensive, but knew that going in and it is needed with any TKO conversion. The McLeod Slik Stik for the '66 came right up through the factory tower. Classic Chevy shipped the trans kit the same day we ordered it (while they were packing for SEMA I should mention) and it was received in 4 days from California to Indiana. Can't wait to drive it as soon as we finish brake lines (front disc changeover as well). Like I said, very impressed with customer service and responsiveness from Classic Chevy 5-Speed! If I get a chance, I'll post some pictures...
P.O.S.I - It's not just a club...it's an addiction!
Smilies are Off
