Old 10-23-2005, 08:37 PM
1157 motor head's Avatar
1157 motor head 1157 motor head is offline
Question 70 GTO 8 TRACK PLAYER LOCATION??
PLEASE HELP IF YOU CAN, I HAVE AN FACTORY 8 TRACK TAPE PLAYER THAT I WOULD LIKE TO INSTALL IN MY 70 GTO . I NEED TO KNOW THE CORRECT LOCATION , FRONT TO BACK ON THE CONSOLE . I HAVE AN AUTOMATIC TRANSMISSION CAR , SO POSSIBLY I NEED THE DISTANCE FROM THE FRONT OF THE CHROME SHIFTER PLATE TO THE FRONT OF THE TAPE PLAYER??
THANKS JIM
Old 10-23-2005, 11:46 PM
Rx:GTO daily Rx:GTO daily is offline
I'll measure mine for you after work Monday and post, unless someone helps you in the mean-time. Mine is also A/T, so I'll try to foto the measurements.
If the glove doesn't fit, you must still convict! '70 Judge RAIII A/T, PS, PDB, BVT, 8-Track
Old 10-24-2005, 03:54 PM
TJH TJH is offline
First, you need all of the brackets to mount it to the console. If you have those, the bottom bracket has four bolt holes which go through the console. Now, remove the forward woodgrain plate on your console. Once removed, you will see four semi-circular cast-in braces on the underside, which correspond to the 8-track bracket bolt locations. These spots were drilled oversized- at around 1/2" diameter holes- for the bolts to pass through. You can use the 8-track bracket and the cast-in locators to put it where it needs to be.
By the way- the factory wasn't terribly precise about this. I have seen the holes drilled 1/4 inch forward/rearward from the center of the cast locations, and the holes themselves allowed for a lot of slop in the position.
Old 10-24-2005, 03:55 PM
Default 8 track
GTO Daily , is your car an origional 8 track option car or did you add the 8 track ?
Old 10-24-2005, 08:20 PM
Jim,
Yep, orig. 8track/console/rally shift. TJH is most likely correct, though. I didn't stop to think (was late when I saw ur post) that the braces would be on console, even if not ordered w/8 track. Makes total sense that there was only 1 piece (ie. the front wood grained panel) and all cars got it. So, best/only way to do this is as per TJH's instructions. No real need for measurements cuz it will be where it will be. If you would need anything else though, let me know.
Old 10-25-2005, 01:02 PM
RAM AIR 1967 RAM AIR 1967 is offline
You will have to find the brace under the console for the 8track.
Old 10-26-2005, 04:27 PM
TJH TJH is offline
Ram Air- that's what I was referring to, when I mentioned having ALL brackets.
That one under the console really is important, as that is what actually supports the weight of the 8-track. The holes in the console plate are through-holes, which allow the bolts to hold the upper (above console) bracket to the lower (below console) bracket. Basically, the console gets sandwhiched between the two brackets, and nothing on the 8-track structurally attaches to it.
Old 10-26-2005, 04:47 PM
Thumbs up THANKS GUYS
THANKS GUYS FOR THE HELP . ITS GUYS LIKE YOU THAT MAKE THIS HOBBY FUN!!
Old 10-26-2005, 07:55 PM
poncho_cruz's Avatar
poncho_cruz poncho_cruz is offline
Here's the Orbit judge with factory 8 track Colins has for sale.
http://colinsclassicauto.com/zoom.php?car=170&pic=25
Old 07-15-2010, 10:05 PM
pmdclassics's Avatar
pmdclassics pmdclassics is offline
Hey guys does anyone have pictures of the brackets or better yet a breakout diagram of the 8 track installation? I am attempting to put back in the factory 8 track and have the player. The four mounting holes are good to go in the console, just wondering about the brackets.
TODD
Old 07-15-2010, 11:28 PM
marxjunk marxjunk is offline
Old 07-16-2010, 08:59 AM
Nice! Thank you. Now to locate the mounting bracket.
TODD
Old 07-16-2010, 09:03 AM
ive put console units in..the little bracket kinda only fits in one spot..
i put tape one the floor, bolt yhe bracket to the console slide the console where it goes, and push down on the front of the console..it will leave marks...pull the brkt and lay it down and match the marks..had good luck...ive also painted the bracket legs with shoe polish for a good transfere to the tape too...
Old 07-16-2010, 09:59 AM
I mean I don't have the bracket. The 8 track tape player was in a box in the trunk, but no hardware.
TODD
Old 07-16-2010, 10:40 AM
ebay.. i saw them repopped..nit sure but think so...look at the pic..the console brkt is smaller and shorter than the pedistal...
this is pedistal mount...im sure is they have these they have console...or check PY...
http://cgi.ebay.com/ebaymotors/1969-...item3ef7c44d70
Old 07-16-2010, 05:16 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
I put one of these repo brackets in my 72 (I have an orginal in my 70), and they are not of very good quality. They get the job done. I don't think it will matter which one you use. You just need to make certain you cut the carpet as little as possible. I think the front part of the bracket would be in the same location as the small console bracket in the front, since the front console hole should line up with that.
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 07-17-2010, 03:52 PM
My car has the console so the aftermarket bracket on Ebay will not work. Good chance I can customize one or there are some guys on the board here that are pretty handy too.....hint...hint.
TODD
Old 07-17-2010, 05:27 PM
no no..go to your post wanting the bracket, i posted a link there to a correct console bracket....
Old 07-18-2010, 09:20 AM
Yep thats the setup.
TODD
Old 07-19-2010, 08:59 PM
I lucked out, found the brackets in the trunk mixed in with other seat parts. Here are some pics....
ID:	212597   Click image for larger version
TODD
