I'm getting ready to pull the body off frame finally! All the bolts are out (only one broken). I have somewhat limited space to work so I've designed a special rack to hold the body that will allow the frame to roll out for work and roll back for storage. The rack is basically made from a heavy duty industrial steel holding system which I modified, trimmed and welded on casters. I need to know how much the completely stripped 2dr post body weighs so I can figure out the best way to lift the body onto the rack. Can the body be lifted with 4 guys? I could get my hands on an oversize cherrypicker and use straps etc. Any suggestions on best, easiest, safest way to get this done? Thanks for any input.
I thought this was an interesting way to lift a body...
http://216.178.81.108/forums/showthread.php?t=457012 |
I've seen guys that hooked chains from front to back seatbelt mounting holes. Push an engine hoist thru the window and hook to the chains. Jack it up. Use your help to keep the body from spinning.
Thanks for the great responses!! Let's see...how many beers does it take 4 guys to lift off a body??? That could get expensive!!! Fork lift in my 1 1/2 car garage....I've got almost enough room to walk now so that won't work, besides my forklift is 20 miles away. ABody....now that sounds like great idea!! I was looking at using a hoist above the roof and never thought about using the seat belt mounts. I'm on the move with that idea. Thanks to all!!
1.5 hour process for the removal not including disassemble. |
when i took the body of the frame on my 67 hdtp completey stripped it took 4 guys
Woah woah woah WOAH!!!
Hold up guys, this needs to be done in a careful matter!!! I agree with members most of the time, but you don't want to make a GTO/mechanic sandwich in your garage I just uploaded some video I shot with my camcorder back in January to document my "redo"...this should give you a good idea of how it's done and what a successful body off the frame ends up being...I just uploaded this to putfile.com so you guys can get an idea. If you've got a buddy who has an car lift and a huge shop (like I did, it will be significantly less stressful and more enjoyable) Click here to watch last-look-at-GTO-before-sandblasting Click here to watch 67-GTO-coming-off-the-frame Click here to watch prep-before-body-removal By the way, excuse the guy's "bowtie on the brain" mentality from the guy with the beard in the videos...he's a chevy guy to the core, but he really lent me a hand in the early parts of my disassembly and gave me access to tools at his shop I didn't have I may be only 18, but I know the right way to do this without problems. hope that helps! Last edited by Bryan Jensen; 10-25-2005 at 11:15 PM. |
There is always more than one way to skin a cat and always a safer way.
24 cinder blocks 3-8' 4X4's posts me and my son one block at a time
Rolled the frame out did floor pans, trunk and one crossbrace frame blasted new springs,shocks,fuel and break lines Eastman chassie black Undercoated shell new body mounts and she is back on the frame all in 30 Days Now my wife was not happy with all the long nights But I got it done It will go to a body shop for primer and paint at the end of Nov then come on Spring Paul |
