Old 11-02-2005, 09:06 PM
70 barn unseen 70 barn unseen is offline
Question hi output alt for 70 lemans????
who sells a 100-130 amp alt for a 70 lemans with ext regulator,400 motor
Old 11-02-2005, 09:41 PM
scratch the itch scratch the itch is offline
You can have your original "built up" at any good automotive electric shop. I think they just rewind it with bigger wire. I just did my 67 GTO, Went from 60 amps to 140. Cost $100.00. Advantage is that you still use an external regulator and maintain that original look. I used Auto Electric in Marietta Ga, they will probably just let you ship it to them. The exterior came back looking new too.If you just want a new one try a truck shop.
Old 11-02-2005, 09:42 PM
beemergaryw beemergaryw is offline
Look for a place in town that rebuilds alternators. They should be able to fix you up.
Old 11-02-2005, 09:44 PM
By the way , you will need a new voltage regulator too if you increase the size of the alt
Old 11-02-2005, 11:10 PM
george kujanski's Avatar
Check out www.madelectrical.com they have a good article on alternators and part numbers of delco 12SI types which go up to about 95 amps in a OEM design meaning they are designed for high current, with proper cooling, etc. not just a rewind which may output over a hundred but not work at idle, or burn up because of insufficient cooling.
George
Old 11-03-2005, 12:47 AM
GoatDr GoatDr is offline
Try www.4alterstart.com. I have two from them and no problems.
GoatDr
