Old 11-04-2005, 09:18 AM
Junkyard Dog's Avatar
Default Lowest E.T. with a Tremec TKO?
Plenty of you are running TKO transmissions now. So, what is the floor on e.t. with one of these?
Is there a point where one cannot shift fast enough to use it, and, if so, where is that point? Nines? Eights?
Who is running 11s?
Step up with your times . . .
Badder than old King Kong
-Jim Croce
Old 11-04-2005, 09:28 AM
Chris Roach's Avatar
Chris Roach Chris Roach is offline
A friend of mine ran 10.89 @ 127 a few weeks ago with a tremec TKO 500. (non Pontiac).
I will be installing a TKO 600 in my JUDGE this winter with hopes of dipping into the low 11's high 10's for next season.
1969 GTO Judge Ram Air III
1968 Catalina "Darkside" Vert!
Old 11-04-2005, 03:23 PM
77TA 77TA is offline
Not that fast, but it should be in the mid 11's if I ever go back to the drag strip.
11.86 last year picked up .3 in the 1/8 this year and added 5 mph..
Old 11-04-2005, 03:58 PM
rzrektd rzrektd is offline
On Vacation
I dont have ETs but I know that the TKOs launch better than a muncie ever will.
I'll post my et's when my car is done 2, 4,6, ??? years from now
Old 11-04-2005, 10:29 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
My 60 ft dropped by a tenth or so but I never got a good full run in. My car did 11.8's on a good day with the old 4 speed. I'm hoping to get down around 11.6 with my tko-600.
_________________________
Sonny Barger
Old 11-05-2005, 12:51 AM
guidos's Avatar
guidos guidos is offline
My best was a 12.54 @ 110, with a bad 1.87 60'. I have the TKO 600 with a 2.87 1st and a .82 overdrive. Great trany, I have a 256/260 duration cam and got 18.75 MPG on a 300 mile trip. I am still hoping for low 12's and maybe a high 11's, once I can figuer out how to launch!!!
Some pictures in the link of the tunnel mods I had to make.
http://members.shaw.ca/rguido/dad.htm
Old 11-05-2005, 04:51 AM
Silver Judge's Avatar
Cool
On this board, FASTGTO runs high to mid 11-s w/a Tremec TKO 600
I've heard of guys going into the 8's with tremec 5 speeds.
My opinion ?
When you're in to 8's, you better keep that bugger on the straight and narrow and you've got better things to do than rowing gears !
And this is from a guy that love 4- speeds
501 HP, 554 ft lbs TQ
Old 11-05-2005, 04:55 AM
That car looks sweet !
Old 11-06-2005, 11:13 PM
suprchikn suprchikn is offline
Finally got her into the 11's late last year and haven't been out this year yet (just got married), but going to Atco next week... I feel like a kid on christmas eve! Any way my TKO is about 4 years old before the 500 or 600. 3.27 1st , and .068 5th. Before this trans I lunched two muncies and since, I've sheared wheel studs and made kind of a mess of a 12 bolt. ALL on bfg drag radials! Oh and twisted the factory (tremec) slip yoke. something to watch!? Anyway I love this gear box. 18-20 something mpg on trips and I drive to the corner, to the shore or to the track. As far as shifting that wont be holding me up for a while. and when I figure out how to launch it I may start to see decent 60's and ET's to match my mph. If attachment works I'm on the left.
Drive it like you stole it... or it will break!...again!
Old 11-06-2005, 11:39 PM
black_bird's Avatar
black_bird black_bird is offline
I know several local mustang guys with tremecs going 10-11's or better. I've heard of 9 second passes, but I've never seen one in person
Old 11-07-2005, 10:44 AM
Superchiken, Odd that the guy in the right lane was 3 mph slower than you but half a second quicker?
-Jim Croce
Old 11-07-2005, 12:59 PM
Yeah, all my timeslips look like that. A stick car will always mph higher than an auto. But look at the 60' -1.957 thats real slow for that et or mph. Ilet the clutch fly at 4000 and it hooked and fell on its face before I was into the gas hard enough. I'm still trying to find a happy launch technique. The top end charge of this car is a real blast. Ray
Old 11-07-2005, 01:23 PM
rumair rumair is offline
not odd at all...look at the 60 ft. times.
my car last week is an even better example. i ran 10.47 @ 125 with a 1.44 60 ft. after making some changes to the car to help with traction. earlier this year it went quicker (10.43) and faster (128) with a worse (1.49) 60 ft. time.
my 97 trans am "only" ran 11.90's, but it went almost 120 mph. that would have been good enough for low 11's with an automatic transmission as opposed to the T-56.
Old 11-08-2005, 11:11 AM
Default 11.8?
So, 11.8 is the fastest Pontiac/Tremec combo out there?
-Jim Croce
Old 11-08-2005, 12:04 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Don't take this wrong guys, but...why are the 60's so slow? You would think that the Tremec with the low 1st woould launch well? How about shifting at the track? Is the 2-3 easy to miss and go to 5? -Jim
Old 11-08-2005, 12:23 PM
gearbanger's Avatar
gearbanger gearbanger is offline
I haven't done any hard shifting with my TKO yet, but I can't see why any of the gears would be easy to miss. The gates are very positively located by the shifter and You have to push it over to the right to get it to the 5th gate. In other words it shifts just like a muncie, only much easier to get it into the gears than a muncie.
Old 11-08-2005, 12:49 PM
tom s tom s is offline
on full power shifts I have missed 3rd a couple times.I believe for a true drag race trans it needs a rev-5th lock out.I usually lift on the 2nd-3rd shift now.My car has the older 500 with 3.27 first gear and 4.56s in the back,1.70s 60 fts.I believe with the 600 first gear it would be 1.60 60fts.Tom
Old 11-08-2005, 12:50 PM
Jim,it does not go into 5th,it hits the "taint",taint 3rd and taint 5th.Tom
Old 11-08-2005, 12:54 PM
gearbanger's Avatar
The gates are very close together on that tranny. Maybe I'll have the same trouble when I get to pound on mine a little. The gates narrower than my muncie was so I might overshove the shifter into the "taint" area until I get used to it. I can't wait to get to grab some gears!
Old 11-08-2005, 02:03 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
11.67/121 with 1.7 60 ft.
