Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 11-21-2005, 10:41 AM
Rugratman's Avatar
Rugratman Rugratman is offline
Default Dash restoration Who?
O.K. one of my plans for the winter is to restore my dash and components.
I plan on doing the dash bezel, gauges, harness, etc...
I could use some tips on the right guy's to use.
1. My dash bezel ...Mr G's?
2. Harness and fuse block.....? M&H or Painless?
3. Tach restoration?
4. Clock resto, quartz conversion?
5. Speedo, and the other gauges?
6. The back of the firewall?
7. The Am / Fm radio?
I also don't want to send something off and not see it for 9 months either. I want everything done by April or so.
Damn, looking to be expensive.:eek: Any tip's or who to avoid?
Also planning on replacing the heater core.
67 GTO.
........I'm just learning as I go.......
Old 11-21-2005, 10:58 AM
winbub's Avatar
winbub winbub is offline
Default Some info...
Rugrat-
I am taking on the same project this winter...however, not to the extent you are. I am going with M&H Fabricators for my new dash wiring harness. I've used them for all of my other wiring harnesses and their product is top notch.
Also, we doing the firewall, don't forget to replace the firewall pad. Definitely helps with keep the heat away from the passenger area.
Good luck with the project.
Jeff
1966 GTO Coupe(#1845), AT, PS, PB, Nightwatch Blue
389 built by Gaydosh Performance - .040 over, 670 heads, 4bbl 750 Holley Double Pumper, Edelbrock Performer intake, Howards CAM and lifters, Scorpion roller rockers, TRW rods and pistons, Doug's headers, new TH350 with shift kit & 2000 stall, 8.2" rear with Auburn carrier & 3.55 posi Richmond gears
http://www.cardomain.com/ride/2240898/1966-pontiac-gto/
Old 11-21-2005, 11:07 AM
Stuart's Avatar
Stuart Stuart is offline
For speedometer/gauge/clock restoration I've had good luck with APT Instruments in Minneapolis, they've done some amazing restoration work for me. I once brought them a motorcycle speedo/tach combination gauge that was literally a pile of loose parts in a box, and they put it back together better than NOS quality. I also had them rebuild a Pontiac factory tach and convert a '65GP clock to quartz movement with good results. Their website is http://www.gaugeguys.com/
I had a dash bezel redone by Mr. G's and was happy with their work. I've heard other people have had problems with his service, but everything worked ok for me.
Old 11-21-2005, 12:08 PM
lkt1954's Avatar
lkt1954 lkt1954 is offline
Dash- Performance Restoriations - Keller, Texas - Darrell Roach 817-431-1888
Gauges, Tach - Pete Serio - Precision Pontiac
Radio - S & M Electro Tech 763-780-2891 This was AM/FM Conversion
All three have done work for me with excellent results (search some of my post for pictures of the dash). It took a little longer than I like, but they were done over the summer, ought to be better now that it is their slow time.
Larry
Get in-Sit Down- Shut Up - Hold On
Old 11-21-2005, 12:47 PM
Bryan Jensen's Avatar
Bryan Jensen Bryan Jensen is offline
On Vacation
Send a message via AIM to Bryan Jensen
American Classic Restorations up your way Rugrat, in Uxbridge Massachusetts....the BEST!!!!!
That's what they specialize in actually, restoration and custom dash and gauge work.
They do AWESOME work and don't try to rip you off like other resto places. They are friendly and don't mind if you call up to see what's going on. They haven't done my dash yet but they just got done on some custom gauge work I had done. They made me a modern interpertation of the factory console-mounted tachometer, using an aftermarket run-in-the-mill mailorder piece as a donor, and it looks KILLER!!!!
http://www.american-classic.com/
Old 11-21-2005, 03:00 PM
vidguy's Avatar
vidguy vidguy is offline
The only personal recommendation I can give here is M&H. I have bought from them for over 10 years. TOP FLIGHT..
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 11-21-2005, 08:44 PM
Ron Landis's Avatar
Default Plastic Chrome
If you are having some plastic rechroming done I would HIGHLY recomend Layson's Restorations They do very nice work. They specialize in Mopar Restorations, but gave me exactly what I was looking at a great price.
1 877-930-4088 Auburn, WA (I worked with Dave, I think he is the owner)
Old 11-22-2005, 12:46 AM
Legendary Legendary is offline
Pete Serio isn't doing the cluster restorations anymore, but he does have the new replacement faces. They are top quality parts, and Pete is a great guy.
Legendary Supercars, Inc.
http://www.legendarysupercars.com
714-209-7167
Smilies are Off
