I have a set of cherry '02 Camaro SS wheels sitting in my garage, waiting for a purpose in life. I want to see how they look on my 70 Le Mans Sport ragtop. I'm in the midst of a restification, having updated the suspension and brakes (Global West negative camber upper arms, tall spindle disc conversion), so I'm open to non-standard wheel diameters if they look good and work well on the car.
If I recall correctly, they are 17" x 9", not sure of the backspacing. Bolt pattern looks close, but I know that the '09 Camaro used a metric bolt size and possibly the pattern is metric as well. I know that spacers/adapters are available for other combinations, just wondering if anyone has done this particular combination. Are there specific adapters/spacers for using these wheels on GM A-body cars? Who makes the highest quality spacer/adapters? Which ones are junk and should be avoided?
Bought: 1970 Le Mans Sport Convertible (second owner,) Palladium silver, 350/2bbl (sigh) with Comp Cams 268H grind (installed by previous owner), TH350 Trans. Mods: Front suspension: Global West negative roll tubular upper arms, Del-a-lum bushings, Koni shocks, 12" disc brake conversion, 1.1" front sway bar, Rear suspension: Global West tubular control arms, springs, sway bar. Exhaust: Flowmaster 2.5" American Thunder system. Mostly complete: Firewall-forward engine compartment restoration Last edited by DIYGuy; 11-25-2005 at 03:56 PM. |
Followup
Here is a site with billet adapters: http://www.skulte.com/ FAQ: http://www.skulte.com/adapterfaq.html 5-lug calculator: http://www.skulte.com/boltcircle.html Photos: http://www.skulte.com/gallery/search...apter&go=Go%21 Here is a 1986 Monte Carlo SS using "Motorsports Tech" adapters for the above-mentioned wheels. http://www.dumpit.org/grimreaper/tires-n-wheels.htm http://www.dumpit.org/grimreaper/ Can't find the website URL for Motorsports Tech - anyone know it? Here's the company address. Motorsports Tech 21800 Barton Rd. Grand Terrace, CA 92313 909.514.0092
Bought: 1970 Le Mans Sport Convertible (second owner,) Palladium silver, 350/2bbl (sigh) with Comp Cams 268H grind (installed by previous owner), TH350 Trans. Mods: Front suspension: Global West negative roll tubular upper arms, Del-a-lum bushings, Koni shocks, 12" disc brake conversion, 1.1" front sway bar, Rear suspension: Global West tubular control arms, springs, sway bar. Exhaust: Flowmaster 2.5" American Thunder system. Mostly complete: Firewall-forward engine compartment restoration Last edited by DIYGuy; 11-25-2005 at 04:16 PM. Reason: cleanup |
I've got a set of 16x8 Fourth-Gen wheels waiting to go on my '69. I bought some used billet adapters, 1-3/4" thick on the front and 1" on the back to space them out. The bolt pattern is the same. You use 7/16" nuts to hold the adapter onto the hub and 12mm nuts on the wheels to the adapter.
![]() Quote:
I'd love to see some pictures if/when you finally get them mounted. It'll be a while before I get around to mounting mine.
Bought: 1970 Le Mans Sport Convertible (second owner,) Palladium silver, 350/2bbl (sigh) with Comp Cams 268H grind (installed by previous owner), TH350 Trans. Mods: Front suspension: Global West negative roll tubular upper arms, Del-a-lum bushings, Koni shocks, 12" disc brake conversion, 1.1" front sway bar, Rear suspension: Global West tubular control arms, springs, sway bar. Exhaust: Flowmaster 2.5" American Thunder system. Mostly complete: Firewall-forward engine compartment restoration |
