Old 12-03-2005, 10:26 PM
BLKBRD BLKBRD is offline
Default Power Brake Booster with Delco Stamp
Neither my '69 Judge or '70 Judge with power brakes and original brake boosters have the "Delco" name stamped on them. Was it basically hit or miss as to whether or not your car was assembled with or without it, or were boosters with the "Delco" stamp used in other years?
Old 12-05-2005, 01:54 AM
Rx:GTO daily Rx:GTO daily is offline
My original does have the stamping (70 Judge), but it is much less prominent than the current repros (which I have currently on the car). Old 1 is in storage now awaiting me spending the $$ on a rebuild & restore.
If the glove doesn't fit, you must still convict! '70 Judge RAIII A/T, PS, PDB, BVT, 8-Track
Old 12-05-2005, 02:05 PM
Rx: GTO daily,
My '70 was built in Arlington in September of '69. Where and when was your car built?
Old 12-05-2005, 02:41 PM
taximan's Avatar
taximan taximan is offline
My 69 has it. Built in Pontiac
Old 12-05-2005, 04:55 PM
LPete LPete is offline
My '69 has it -- it's upside down straight below the check valve. It's not stamped very deep -- one end is barely legible. I'd take a picture, but I just sent it to get it replated.
Old 12-05-2005, 05:08 PM
My Freemont '69 does not have it.
Old 12-05-2005, 05:48 PM
Often when original Delco-Morraine boosters are "restored", the front "shell" is glassbeaded & buffed to a point where the DELCO script is gone or barely legible. The worse the minor pitting, the more the outer case will have to be buffed. Good reason to keep nice extra core boosters inside, properly stored, & only use quality cores for high point restorations.
Old 12-07-2005, 02:55 AM
BLKBRD...mine was 2nd (or 3rd week of November..always forget) in Pontiac. I was there when my mechanic replaced it and there is NO doubt it was the original. No question those nuts had not been moved for 35 years!! We also immediately noticed a difference in the way the front (engine side) seal was done. The original seal slipped over the actuater shaft and simplely presses against the face of the booster. The repro seal was integral with the booster. Much nicer design. Unfortunately required spacing the master cylinder out from the booster....would have been nice had spacers been provided by the manufacturer or year 1. Of course, this is not the only time I have been left hunting for "extra" (using that term incredibly loosely) parts by year 1. Why don't they tell us these things a head of time?? It seems to me that yr1 has out grown itself.
Old 12-10-2005, 02:09 PM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
my 70 fremont build has it>>upside down , on check valve side. still there after restoration.
70 GTO 400/[email protected]
Old 12-20-2005, 02:26 AM
oxfordsteve oxfordsteve is offline
Send a message via Yahoo to oxfordsteve
My 69 has it-upside down under the valve.
