Old 12-11-2005, 04:17 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Pictures of the new blast cabinet
Here's the new cabinet and how much room with a Victor in it.
Old 12-11-2005, 04:18 PM
Skip Fix's Avatar
Here's the bafled rear port, 4" metal hole 3 7/8 with grommet.
Old 12-11-2005, 04:23 PM
Skip Fix's Avatar
non baffled side port. I actually found a vacuum attachment that has the exact screw spacing I can use to suction for the Shop Vac. I would think though the baffled one would be better to decrease larger media getting sucked up. But then the other hole media might blast out without a baffle.
Not bad for $124.00!
Old 12-11-2005, 04:29 PM
Hammered's Avatar
Hammered Hammered is offline
Skip,
That's the exact same cabinet I bought about 2 years ago. I just inserted the 2" flexible hose for my shop vac into the hole on the left side and went to town. By far, it was worth the money. Probably the best Harbor Freight tool I ever bought.
Order yourself a bunch of tear offs because you'll need them.
John
1967 Firebird Convertible Factory 400/4spd
Now 462/5spd Fuel Injected
http://1967firebird.atwebpages.com/
Old 12-11-2005, 04:41 PM
Skip Fix's Avatar
This one wasn't even in the catalog, but was at the local outlet. It's larger by alot and only for a little more than the other table tops. I'm going to add some handles on either side to make it easier to carry.
How's the EFI project?
Old 12-11-2005, 05:41 PM
Skip Fix's Avatar
Here's a picture of the carrying handles and vacuum connector.
Old 12-11-2005, 08:17 PM
Hammered's Avatar
Skip,
Yeah, they quit carrying it shortly after I bought mine and I haven't seen one in our local store for more than a year now. But like you said, it's larger than any of the other models for about the same cost.
Another thing I forgot to mention is that you need to make sure to recaulk the seams inside the cabinet before you use it. I also had to replace the door gasket because it was so poorly installed. Not a big deal, but those little gaps will lead to lots of sand on your bench top. I also bought a 1' neon light and velcro'd it to the inside top of the cabinet. Make sure to put a switch on the outside of the cabinet as the grit will foul one on the inside.
The EFI project is coming along swell. I updated my website today in fact. I spent yesterday tuning the idle and no-load conditions up to about 3,500 rpm. I've got it about 95% there but want to refine it a bit more. I'm thinking of leaving the engine in the car and skipping a follow-up dyno session as I'm busier than ever and want to get the car done.
I posted some pics in this thread this morning: http://216.178.81.108/forums/showthr...80#post2367080
John
Old 12-11-2005, 08:50 PM
md1twal3 md1twal3 is offline
What purpose does the vacuum connector serve for a blast cabinet? Just curious as I am just learning about them...
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi
Old 12-12-2005, 01:10 AM
Skip Fix's Avatar
They help keep the dust out of the way so you can see better what you are doing.
Old 12-12-2005, 05:22 PM
Fish On Fish On is offline
Default Bead Blaster
Skip Fix,
I noticed your thread over the weekend and decided to head for Harbor Freight today to see if by chance they had a cabinet like the one you purchased. Sure enough, they have them in stock. But wait...theres more. I go to check out and they ring it up for $99.00. I asked if by chance I had the wrong box, and she said no, that the Cabinet is on sale and the $99.00 price is correct! Now all I have to do is figure out how to get it into the shop without my wife seeing that I bought more stuff for myself just before Christmas!
All the best,
Fish On
Old 12-14-2005, 12:15 AM
Kron Kron is offline
Whats the model make on the blast cabinet. I'm looking for an inexpensive unit that I can mount on a mobile stand. I'm looking at the small table top one from TP Tools but the one listed here looks pretty nice for $124...
Tony
Old 12-14-2005, 12:31 AM
formula400's Avatar
formula400 formula400 is offline
just for your info check out www.tptools.com
they got really good prices on scat cabnits,i just got one from them,really nice units
i got the 976 pro detailor xh
also they come pretty much assembled,and very quick shipping,had mine in 3 days
Old 12-14-2005, 12:37 PM
A-body A-body is offline
Here is a tip I used on my blast cabinet. On one of the hose conections, I drilled a 3/8 inch hole thru both parts (where the sections overlap. I can then adjust the amount of suction in my cabinet by twisting the hose, and opening or closing the holes. It doesn't suck as much media in that way.
Gary
Old 12-14-2005, 05:04 PM
JLHarper's Avatar
JLHarper JLHarper is offline
Good idea...Gary. Thats the same problem I am having with same model in home shop.
Also...
Did any of you use the plastic sheets to cover the window on inside? Mine came with two sheets and had a adhesvive area around permemiter but wouldnt stick so I took it off.
Woder if window will fog up bad with light use? Guess a new one can be istalled with out much cost should it come to that.
Jeff
Old 12-14-2005, 06:13 PM
Default Blast cabinet
Aasimone,
If your question was regarding the Harbor Freight unit, it seems to be their own brand which is Central Pneumatic. I could not find another name on the cabinet. I think the model number might be 42202, but don't quote me on that. Good Luck,
Fish On
Old 12-14-2005, 08:08 PM
Tigerpaw65 Tigerpaw65 is offline
Smile
By not using the glass shield you will be blasting the inside of the glass as your beads bounce off the metal piece your cleaning.
I get my supply from WalMart, material dept, cut it to size, use 3M two side tape (found at the better office supply stores). Some days I'm sitting in front blasting almost all day.
I put the dust collector in the storage barn to get the noise level down in the shop. Works quite well this way. Some times I use a personal walk man to pass the time.
Enjoy your new toy.
Tigerpaw65
Old 12-14-2005, 09:05 PM
Tigerpaw65,
Does the clear plastic come in sheets or rolls?
Fish On
Old 12-14-2005, 09:44 PM
firebum firebum is offline
I think it is very important to caulk the inside joints, as Hammered said above.
I didn't do it and fine dust leaks out all over. I will caulk mine before the next time I use it.
Jim
1973 Trans Am 4-Spd 455, #'s Matching
1973 LT/RS/Z28, 4-spd, 28K Milies, #'s Matching
1972 Camaro 4-Spd
1975 Camaro
2000 C5 Coupe
Old 12-14-2005, 11:43 PM
Skip Fix's Avatar
42202 Harbor Freight.
