Old 12-23-2005, 04:36 AM
rfb92345's Avatar
rfb92345 rfb92345 is offline
Send a message via Yahoo to rfb92345
Default Comments
Here's the car.......3030 lbs with out driver, .030 over 400, 10-1, .525 lift, 284 (?) dur, Virgin E-heads, Victor intake, 850 Demon, headers, MSD, TH400, 4.56, 2500 converter. Car runs consistant 11.70 @ 3000' with a sucky 1.8 60ft. MPH is arond 115. The engine is apart now for some porting on the heads to hopfully go from 278 to up over 300. Going to a bigger solid cam, up the compression to around 12.5 and getting a decent converter. My question is, with our old combo, is that about right ? I mean considering that we had the tight converter and sucky 60ft ? We are hoping that with the improvements, we can get a decent launch and get into the low 11's or high 10's at sea level. Just thought I'd throw it out there and let you guys chew on it........
Old 12-23-2005, 12:10 PM
fasteddy's Avatar
fasteddy fasteddy is offline
That should run in the 10s for sure at sea level. A car weighing 3030 should 60 in the high 1.4s with that combo. What tires and suspension ya running. Get a decent converter and hook it up and I would say 10.80s are in your future.
fasteddy
Old 12-23-2005, 12:53 PM
SlowSpitzer's Avatar
SlowSpitzer SlowSpitzer is offline
Converter, at least 4,000 rpm.
Steve
Yea, I know, the heads suck!
2005 Cordova Q16 Winner!
2005 Norwalk Sat Top ET Winner!
Old 12-23-2005, 01:49 PM
WARPed's Avatar
WARPed WARPed is offline
That 4.56 gear is a lot. What rpm are you seeing in the lights?
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 12-23-2005, 05:02 PM
herdsman's Avatar
herdsman herdsman is offline
Just to compare....
our 65 GTO with a .030 over 400, 670 heads ported by Mark Kauffman, 9.48 cr, Comp Cam XR288HR cam, 93 octane pump gas from Giant Eagle, 4500 stall converter, Torker I, 750 ProForm/ Holley by Tom Vaught and myself, T-400 transmisson by Cliff Ruggles, 12 bolt with spool and 4:11 gears, 28x10.50x15 M/T slicks, race weight of 3478 lbs, up here in sunny Ohio at Norwalk with an adjusted altitude of 2800-3200ft, 11.70s @ 115-117 all the time. So I think that you already have a strong 11 second car. We shift at 5800 and cross the finish line at 5900rpm. With the 4:56 gears we went 12.2-12.4 @ 110-112mph. I hope this helps. If there is anything that I can help with just ask.
"What we have here is, failure to communicate"
Old 12-23-2005, 05:18 PM
rfb92345's Avatar
Fasteddy...I figure just with a converter change, with the old combo, we coud cut 3 tens of our 60'. That would give us a 11.40 or so. Then if we corrected for altitude, should put us aroiund 11.10. With some more inthe motor, that should give us high 10's....I hope. He is running a 14.5 Hoosier and a 4 link.
Slowspitzer.....Yes, we are going to shoot for 4500, but that will depend on what cam we choose.
Warped......The car belongs to my son, so I'm not totally sure what size tire. I do know it's a 14.5 at around 30".....I know he shifts around 6200 and goes thru around 5800, but I may be wrong on that.
Herdsman....Sound like our old combo is close to yours. I hope that more cam, compression and converter will do the trick. This is about as far as he is going to go with this car. Any more and it's juice time.
Old 12-29-2005, 12:44 AM
CPL.BEYDLER CPL.BEYDLER is offline
Who drives this car, rfb92345? He better get this new engine combo together. I wan't to see the results.
