Old 01-05-2006, 05:17 PM
MRGTO2U MRGTO2U is offline
Default 428 gas mileage
Hi everybody!
My 68 GTO has a 428, Carter AFB, Headers, 6X Heads, Ultradyne 1/4 Cam, etc. It made 385 rear wheel HP at the dyno. Even driving easy only punching it once for a whole 21 gallon tank of gas I only get 7.5 MPG. Does this sound right? I fill it up with 93 Octane and I get 150 miles, thats it.
Please tell me if that number sounds ok. I really do not want to change anything because she runs like a beast.
Thanks,
JG
Old 01-05-2006, 06:34 PM
Ollie's Avatar
Ollie Ollie is offline
Default gas Milage
Who cares about gas milage when you have the FUN FACTOR.
Its ok to giggle and snicker, Dont laugh and point
Old 01-05-2006, 07:11 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
yup. I purposely do not calculate gas mileage in my pontiac. If you want a fuel efficient car, get a honda.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 01-05-2006, 07:40 PM
BVR421's Avatar
BVR421 BVR421 is offline
Similiar 428 in a heavier Bonneville. I get 12+ around town. I suggest a tuning problem.
Vacuum advance on the distributer? on mine it makes a huge difference on the street, not only with making the idle circuits work better with a 230 degree cam, but the increased timing gets WAY better gas mileage and healls greatly with heat in the summer. That car has a Qjet, Ive used a late type AFB and it ran well but used more gas though not as much of a gas hog as when I tried a Holley.
Old 01-05-2006, 08:04 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Tranny? Rear gears? My 400 gets 11.5 on the highway, is that good or bad? It runs like hell thats all that matters! Maybe a fuel leak?
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 01-05-2006, 08:44 PM
JKGTO's Avatar
JKGTO JKGTO is offline
My 68 GTO with 400@350HP, M20 and 3:55 gear only got about 10 mpg around town and 12 on the highway. That was when I drove it easy too! Didnt want to check mpg when I was hammerin' on it. Jim
74 LEMANS GT 350 4SPD MAROON
Old 01-05-2006, 10:02 PM
THEGTOCHISM's Avatar
THEGTOCHISM THEGTOCHISM is offline
Gas milage what's that? Seriously have you checked your distributor vacume advance, and total timing?
Old 01-06-2006, 02:32 AM
Karch Karch is offline
Carb settings, float levels, fuel pressure, vac. advance, initial timing, cam, so many variables.
Biggest is driving style.
What else...slipping trans, rearend bearings, ft. wheel bearings, brakes dragging, going uphill too much
Altitude...
How many of you have driven over 340?
Old 01-06-2006, 06:09 AM
Geoff Geoff is offline
Sounds like there is a Holley under the AFB skin!! LOL.
Is the choke adjusted correctly? Check the power pistons are not stuck in the UP position, check jetting if the carb history is unknown. Check the float level; Carter publish a chart that correlates fuel pressure to float level & needle & seat size. These factors effect final float level & are all interrelated. Also make sure the vacuum advance is connected to manifold vacuum for best idle quality & fuel economy.
Old 01-06-2006, 08:09 AM
Tranny: Turbo 400 with B&M street mild shift kit.
Rear gear: Brand new 3.55 Auburn Posi
Car had when I bought it last year a 2.78 open rear that I replaced 2 months ago(major improvement). The only draw back is that at 60mph she does around 3100 rpm. But acceleration is so much fun now. As I can see I am not so far off on mileage. I have the original Quadrajet but I understand that if I use it, performance will decrease.
Old 01-06-2006, 08:49 PM
66bonne's Avatar
66bonne 66bonne is offline
I don't get mileage with my 455, I get yardage.
Old 01-06-2006, 10:42 PM
BVR421's Avatar
what sadly misinformed person told you that?
