Old 01-17-2006, 08:17 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
Default For those who have done a front disk conversion
I've seen a few conversion solutions out there. What is your opinion on the swap you did and which setup did you go with? I'm about to do a swap on my sister's 63 wagon...
Old 01-17-2006, 09:51 PM
tom s tom s is offline
scarebird has a bracket setup.Ken at East West has used a Volvo setup and a few of us have used the Wilwood 9in ford rear setup.I have them on my wagon and my coupe.Very happy with them.Tom
Old 01-18-2006, 02:32 AM
R 70 Judge's Avatar
Here is the Wilwood set up Tom is referring to. I will be running the same set up on my car.
Big thanks to Dave Johnson for doing all the engineering work!
ID:	39330   Click image for larger version
James
1970 Trans Am
Old 01-18-2006, 11:09 AM
R 70 Judge's Avatar
Here's the link to Scarebird's '61-'63 Tempest kit.
http://www.scarebird.com/12802/13301.html
James
1970 Trans Am
Old 01-18-2006, 12:34 PM
White Warrior White Warrior is offline
Actually,Rick Johnson did the engineering work on the Tempest Wilwood disk brake
. I made some refinements to it and I am very happy with it.
Old 01-22-2006, 02:45 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
I used the parts that Mark at Scarebird made for me & the list of parts I needed to go & buy from NAPA. Everything fit & worked fine. The car stops 10 times better now than it ever did with the stock 4 wheel drums! I went with a MC from a ford Fairmont that had a 7/8" bore & did not need use any power assist & they still work great! I would use Mark's parts again. I also went with those speed-bleeders at all 4 wheels, those they sell at Jeg's, $10 for a pair; & those save a lot of time getting all the air out of the lines. I also bench bled the MC before I put it on my firewall.
Peter Serio
Owner, Precision Pontiac
Old 01-22-2006, 02:56 PM
Default 1963 Lemans Front Disc Brakes from Mark @ Scarebird
Here are the brackets that I got from Mark, the other parts I bought new fom NAPA, they got a core charge on the Calipers so I brought some with me. I got them at the junkyard for about $2 or $3 each, I used the ones off of a 1984 Pontiac Trans Am. NAPA charges like $15 or $17 per as their core charge.
ID:	39866   Click image for larger version
ID:	39867   Click image for larger version
Peter Serio
Old 01-22-2006, 06:52 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
Peter, did you have to use longer studs on the hubs? If so, do your recall what length? Thanks
[SIGPIC][/SIGPIC
Old 01-22-2006, 08:16 PM
Jon Wood Jon Wood is offline
I just finished installing scarebird's setup. It went together fairly easy. Be sure you grind down the head of the upper bolt that holds on the bracket for rotor clearance. If you use the Strange Engineering master cylinder (B3359) be prepared to cut away part of the sheetmetal bracket that runs from the stock master cylinder mount foreward along the wheelwell. You will also have to create some clearance for the brake lines using a ball-peen hammer.
Old 01-23-2006, 08:50 AM
spartazoo's Avatar
spartazoo spartazoo is offline
Good question, longer studs on the hubs? I actually have mine with me today to drop off and have longer studs installed.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 01-23-2006, 10:25 PM
beemergary's Avatar
Default disc conversion
I used the wildwood set up. Made my own brackets out of 1/4 aluminum. Used original brake hoses. Countersink the top hole and use a allenhead coutersunk bolt to take care of the clearance problem. I used longer wheel studs to mount my american racing wheels. [email protected]
Old 01-26-2006, 02:04 AM
Yes I used 1/2" -20 by 1 & 5/8" front studs. The Ford MC I used has the
line outlets on the side that faces towards the engine which eliminates any
cutting or grinding of original sheetmetal or that tri-angle brace for line
clearance.
Peter Serio
Old 03-27-2006, 04:28 PM
Mark W's Avatar
Mark W Mark W is offline
Anyone have a part number on the Weatherhead 7/16 nut to 3/8 inverse flare
adapter? i cant seem to find them.
Also, what are the torque specs on the braket bolts?
