Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 02-06-2006, 01:59 AM
Hard-Timess's Avatar
Hard-Timess Hard-Timess is offline
Default Need Help Identifying Engine Codes
I would appreciate help in identifying the following engines.
Block / Date / Casting#
____________________
XX ,,,,, L199, 9799914
(blank) B191, 481988 (complete shortblock)
YS ,,,,, C048, 9790071 (complete #s matching)
YS ,,,,, D308, 9790071 (complete shortblock)
Thanks, Truman ([email protected])
Old 02-06-2006, 09:44 AM
Ron Landis's Avatar
Default XX...
is also the code for my original '69 GTO engine...2bbl., 265 hp.
Old 02-07-2006, 12:38 AM
Default Cornfused??
The responses do not coincide with the blocks I am looking at. Both the XX L199 engine and the 481988 engine have 4bolt mains. Thus I don't believe them to be low performance 2barrel carb engines. What gives? T
Old 02-08-2006, 02:18 PM
The XX code 2 bbl engine was also available in Birds.
The XX in my Esprit had the block drilled and tapped for 4 bolt main caps but used 2 bolt caps. (also has 12 bolt rear-end :))
The 72 block is strange, I didn't think they made a 4 bolt drilled 400 block after 1970, except maybe as a SR block.
Smilies are Off
