Old 02-16-2006, 11:13 PM
nosliw nosliw is offline
Default transmission kickdown
my 67 tempest idles at about 1,000rpm, and when put into gear it drops to about 500rpm.
is that too much of a drop? sometimes if it isn't warm enough outside (like today) it idles in park at 800rpm or so and drops down to 400rpm (barely alive)
how do i adjust this? is there a way for it to just stay the same rpm in P and D?
thanks,
alex
1967 tempest
2dr coupe
2spd automatic column shifter
326 4bb
Old 02-16-2006, 11:57 PM
wheelspin's Avatar
Arrow
to the Forums.
To obtain a steady low idle speed; set the idle mixture screws for the highest vacuum reading, or lacking a gauge, the highest idle speed (with a FULLY warmed motor). Then adjust the idle speed screw to the lowest steady speed in DRIVE (block the tires and set the e-brake). Engine temp affects the idle, as you have noticed.
The idle speed in neutral will always be higher than in drive due to the converter/trans drag loading the motor.
It also helps to set the initial (crank) timing to around 12 degrees with around 22 degrees in the distributor for a total of 34 degrees.
Les
Les Iden
Old 02-17-2006, 12:09 AM
thanks for the quick reply!
i think that answers it, i'll do it tomorrow.
