Old 02-28-2006, 10:59 AM
jamesgennock jamesgennock is offline
Default 70 GTO / Lemans core support same?
Are tghe core supports the same for a 70 lemans and a 70GTO? Thanks
JJG
Old 02-28-2006, 11:13 AM
steve v's Avatar
steve v steve v is offline
James,
They are different. The top part on the LeMans core has a lip that bolts to the header panel & the GTO core is flat.
Old 02-28-2006, 10:44 PM
TJH TJH is offline
As noted, the upper section is not even close.
Old 03-02-2006, 12:21 AM
matt1970pon matt1970pon is offline
hey I just got done a 1970 lemans sport that had bad rot around the battery.The lower section of the core support is the same as a GTO so if your problem is there you could always buy a gto core and cut off what you need.Sometimes you gotta do things that you wouldn't ever thinlk you would do.
Old 03-02-2006, 10:06 PM
TJH TJH is offline
Since the new (and VERY nice) reproduction core supports came out, there no longer is any reason to perform the surgical graft that you did, Matt.
Old 03-02-2006, 10:07 PM
TJH TJH is offline
A clarification- James is working on a 1970 GTO... I think Matt thought it was a LeMans that was being repaired.
Old 03-02-2006, 10:41 PM
Yes its a 70 GTO. ANd I figured out what happened. I was looking at my digitals from the body shop after the car was painted and the nose and fenders line up awesome. Then I had it towed home!! I believe the guy hooked onto the bottom of th ecore support some how and that is what made the already unknown weak core support pull away from the bushing and tear. Thanks for all of your help so far. I am looking forward to this repair!
JJG
