Old 03-06-2006, 10:15 PM
GTOINDY GTOINDY is offline
Cool transmission crossmember
Hello
What did everyone use for a race car crossmember? I don't have a stock one so should I just build one or buy one. Should I use the rubber shock mounts on the frame or not?
Old 03-07-2006, 12:07 AM
JOE DEYTON's Avatar
JOE DEYTON JOE DEYTON is offline
I have one out of a Chevelle which is a little lighter than stock BOP a-body, with no rubber on the ends. I also thought about a chrome moly one, Lemons headers lists one for Chevelle that should work on all 64-72 A's except conv.
Old 03-07-2006, 12:47 AM
Default trans mount
Sound like I should be looking for a Chevelle mount it would put some chevy parts to good use. That one from Lemons is a little pricey
Old 03-07-2006, 02:15 AM
02Hawk's Avatar
02Hawk 02Hawk is offline
Why not build one
Old 03-07-2006, 08:49 AM
Default build one
Wow that looks nice great job what does it fit? Mine is a 72 a-body.
Old 03-08-2006, 05:42 PM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
Check the enclosed site, they make a crossmember for your car. http://www.geocities.com/gforcejohn
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 03-08-2006, 08:12 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Robert, that site says it will NOT fit a GTO, or any other rubber mounted type x-member car?
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 03-08-2006, 08:47 PM
dean cummins dean cummins is offline
I have 72 GTO, I have stock crossmember,I didnt use rubber.I made 4
aluminum shims, 2 per side, I think qtr in thick.
72 GTO 11.38 , 1.52 60 ft.
Old 03-08-2006, 08:53 PM
Ok, thanks for correcting me, i didn't read the entire site as i just glanced through it. Sorry about that.
Old 03-08-2006, 09:11 PM
Jagtec1's Avatar
My problem with the stock crossmember is that I cannot extend my 3 1/2" collectors beyond it...I'd like to run mufflers, but can't. I may have to try the shim thing. If I shim it up a bit, I may gain a bit of clearance. I also have a poly trans mount, which may be a touch taller than a stock mount. I'm going to pull it out to see if I can shave it, or check it VS a stock mount. I really want to run the race bullets I have...Open headers are OK, but I feel I may have a beter chance of hearing a problem with the mufflers.
Darin
9.81 @ 136.39MPH
Old 03-08-2006, 11:03 PM
Jag w/ your et , solid c.m. couldnt hurt.Pitch rubber,measure shims needed
w/ c. m. cntrd between bracket and top of frame,add a little to thickness
for good pinch,your done.I used steel motor mt. I have header ground clr
problem.Takes 4 guys to get it off trailor lol.
Old 03-08-2006, 11:37 PM
02Hawk's Avatar
The one in that we built in the picture is for a 70 GTO so it should be the same as a 72
It was designed to work with a full 3 inch exhaust. Saved over 11 lbs
Old 03-09-2006, 10:26 AM
A.W.Dille A.W.Dille is offline
I have one from a 70 Chevelle in my 71 GTO and no issues on exhaust clearance, alot stiffer than the stock unit.
Old 03-09-2006, 08:31 PM
goatasaurus rex's Avatar
goatasaurus rex goatasaurus rex is offline
welded a custom fit "tongue" to crossmember and discarded the rubber bushing and "clamp" bolted it right to the frame. had to cut a notch in the front side of the crossmember to clear the header collectors.
