Old 03-07-2006, 05:08 PM
gumbys goat's Avatar
gumbys goat gumbys goat is offline
Default will 16x8s rub on a 70 gto?
I have a 70 gto will 16x8 from wheel vintiques rub the front when turning the wheels? or should i be safe and go with the 7s?
Old 03-07-2006, 05:31 PM
Northern Goat's Avatar
Northern Goat Northern Goat is offline
The wheels themselves won't rub. The only rubbing you have to worry about is the tire. Depending on width or sidewall height you may rub. But you would have the same problem regardless of 7 or 8" wheels.
If you are happy with the look of your current tires and just want to upgrade to a larger wheel try the following link. You can enter your current size and then plug in 16" sizes to match your overall diameter, tread width ...
http://www.1010tires.com/TireSizeCalculator.asp
WORK HARDER. Millions on welfare depend on you.
David Jones's Avatar
Probably depends on the backspacing and tire selection.
Old 03-07-2006, 06:31 PM
19firebirdrestorer68 19firebirdrestorer68 is offline
If i wanna put wheel vintiques 15x7" all around on my 68 firebird couple, will those rub
Old 03-07-2006, 06:41 PM
i guess my question should be with 16x8s what tire can i put in there?
Old 03-07-2006, 07:33 PM
Shadowjack Shadowjack is offline
Can't reiterate the importance of figuring or stating backspacing too much. I have a set of 16x8s from a 4th gen Firebird--6-3/8" backspacing. They will obviously not clear without spacers. You'll need no less than 5" BS to center the wheel, after that you can get a 245/50-16 on them.
Old 03-07-2006, 08:58 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
I had a set of 16 x 8 wheels with 245/50/16 on my 64 and 66 Tempest. they had 4 3/4" backspacing. Still have em for sale if anyone is interested. American racing wheels. There were originally on my 87 Firebird I had.
