Old 03-21-2006, 05:15 PM
LuxLeMans LuxLeMans is offline
Default Safari 307 Olds bogging down.
Along with my '72 Luxury LeMans, I also have an '88 Safari Wagon with the stock 307 4v Olds "Y" code motor in it.
Within the recent weeks, I have noticed a handful of times where it surges/bogs when I am around the 45-55 mph range, and going slightly uphill.
My gauges show no deviation in temp, voltage. The tranny is quiet too. So I believe it is a fuel problem.
I went to change the fuel filter, only to find the front nut from the gas line is seized, whereas the big nut on the housing is pretty easy to turn. Beyond the fuel filter, I have been advised my fuel pump might be going out.
Any advice?
Old 03-21-2006, 10:30 PM
Pontiacmuscle's Avatar
Pontiacmuscle Pontiacmuscle is offline
Send a message via Yahoo to Pontiacmuscle
use some PB blaster on the fuel line nut which I think is 5/8...carb filter housing nut is 1" get the line broken free and change the fuel filter. You want to be careful reinstalling the fuel filter housing onto the carb; it can be crossthreaded and that sux.
My 454 in one of my other 1 tons ran like crap....2.48 cent fix. Let us know...
ARROWHEAD ADDICTION: An incureable disease contracted from the pointed edge of classic pontiacmuscle; all consuming, taking over mind, body and soul.
Old 04-02-2006, 03:33 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
Default GM tech 1
88 GM car is equiped with electronic mixture control solinoid 4 bbl carb and a ecm(electronic control module) controls that , other than basics , is the "check engine" light on ? if so , have you pulled codes ?
very simple cars to work on compared to modern day OBD II cars !
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
