Old 03-22-2006, 05:52 PM
MadHippo MadHippo is offline
Default Louis Tool
Bought one of these to elongate my pushrod holes. Problem is that the only way i figure it goes in the slot, it moves around quite a bit, so im not sure how accurate Im being. Does anyone have a picture of the proper placement for this thing? these are #62 heads if it matters.
thanks again....
Matt
Old 03-22-2006, 06:15 PM
Ollie's Avatar
Ollie Ollie is offline
Whats a louis Tool?
I have Spotts elongation tool, bolts in the rocker stud hole, yes it does move around if you are using a hand drill, works better if you can use a prill press. and high speed.
Its ok to giggle and snicker, Dont laugh and point
Old 03-22-2006, 06:48 PM
screamingchief's Avatar
screamingchief screamingchief is offline
The "original' louis tool is designed to work on small block chevies mostly,not really for pontiacs,the SBC pushrod slot holds it in place better than a pontiac pushrod slot would.
The spotts elongation tool is a louis "style" tool,but it is different so it works better on our pontiacs than the "original" style louis tool.
Old 03-22-2006, 11:18 PM
damn... i knew something didnt look right. alright I'll get me a spotts tool. thanks for all the help guys.
Old 03-23-2006, 12:18 AM
ChrisTransAm78's Avatar
ChrisTransAm78 ChrisTransAm78 is offline
I used a long rod that I got from home depot (mounts in drill) and a side cutting drill bit (which it then mounts into the rod) - of course my heads were aluminum and went faster than yours prob will...
