Old 04-03-2006, 12:06 PM
takid455 takid455 is offline
Send a message via AIM to takid455
Question urethan bumper paint removal
what is the best and fastest way to remove paint from the front and rear bumper covers of 2gen t/a's? do you have to sand all the way down to the unrethane? what is used to fill i gouges and imperfections that primer will not cover?
1972 HO Trans Am auto White/white
1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue
1978 Trans am gold/ black ,T56, t tops, EFI 474,
Build: http://www.pro-touring.com/showthrea...1978+g+machine
1999 30th Trans Am 6 spd, T top
Old 04-03-2006, 11:15 PM
Philcol Philcol is offline
My body man scuffs the paint with course paper and fills the gouges and cuts with JB Weld then primes.
Phil
"dreamed I was wide awake........woke up and I was sound asleep"
Old 04-03-2006, 11:23 PM
69RamAirDave's Avatar
69RamAirDave 69RamAirDave is offline
Send a message via AIM to 69RamAirDave
Sand it down, dont use a chem stripper. The chem strip can soak into the urethane and cause problems later. You can use a small orbit da for the larger areas, but youre pretty much stuck with doing the corners and edges by hand. Slow process, for sure.
Its usually best to sand all the way down to the urethane. That way you remove any of the old lacquer product that could make its way back to the surface and cause cracking down the road. As for fixing the cracks, 3M makes a good product made just for this.
Never heard of using JB Weld for this before. Does it have enough flex in it?
dave
1969 GTO RAIII/4spd, Palladium Silver/Black/Black, PS, PB, AC, Hideaways, Wood Wheel, Rear Defog, Reverb, Remote Mirror, Console, Rally Gauges, SoftRay, and a ton of paper. Garaged, but not a queen.
Build em how the designers and engineers intended them to be
Old 04-04-2006, 08:26 AM
Paul Brezinski Paul Brezinski is offline
HAD MINE SANDBLASTED AND IT CAME OUT GREAT !!
Old 04-04-2006, 05:13 PM
convgto convgto is offline
Just picked mine up at the sand blasters yesterday, turned out great, he used glass bead. I paid $75.00, well worth it to me.
Ken
Old 04-04-2006, 08:00 PM
cnc's Avatar
cnc cnc is offline
any pics of the result of blasting
Old 04-05-2006, 06:19 AM
paintdaddy paintdaddy is offline
I would not sand or strip with chemical stripper,both will warp the urethane,Id suggest buying new if you can.
Owner-Atlanta Auto Restoration
www.engelsrestoration.com
http://www.picturetrail.com/gallery/...me=engelsresto
Old 04-05-2006, 10:33 AM
68alpinebluegto 68alpinebluegto is offline
I also sand blasted the one on the 70 Judge. I lowered the pressure down to where it was just taking the paint off... it took a while but turned out great and left the factory black sealer on the bumper.
Survivors, frameoffs etc http://community.webshots.com/user/firstgenaddict
68 GTO HO 4spd Alpine Blue over Parchment headrest (paused while I restore other people's cars)
70 Judge Conv. RAIII 4spd 4.33 I painted for a friend. http://rides.webshots.com/album/187328041oxAXRI
Old 04-05-2006, 04:50 PM
79grprixjoe1 79grprixjoe1 is offline
Kent and Fusor both make bumper repair material that comes in a tube form you can get at body shop supply store.It is sandable and I have seen it used to fill in scratches and gouges.
Old 04-05-2006, 07:37 PM
Formulabruce's Avatar
LOL, NEW?? hehe
" Long may we DRIVE !"
Old 04-05-2006, 07:40 PM
JB weld has its purposes, and this isnt one of them. Although it might be ok for a while in a area that may not flex. the #M urathane crack sealer is best, and flexes, and adhears well.
