Old 04-04-2006, 08:37 PM
ModifiedPONPON's Avatar
ModifiedPONPON ModifiedPONPON is offline
Default Need info on Motor Mounts for '73 Formula 350
Hi, I'm Johnny Cash,
I'm trying to put a Chev. 402 Big Block into a 1973 Pontiac Firebird Formula 350 for a Race only application. I would like to use solid motor mounts. I also have a new Chev. TCI TH400 that I will need to install. I would like any info. anyone has to install this combo.
I know you guys are all Pontiac and that's cool. I would like to put a 455 in, but I already purchased these parts and I'm stuck with them. I was going to put them into my '89 Camaro until I found what a nightmare it will be. I found this Bird instead.
Way down the road I would like to restore this car back to original specs also, so I don't want to chop and grind to much on it.
My main question here is what motor mounts do I use and where do I get them from? Moroso doesn't list a mount for '73, They do list a mount up to '72 and '74 on up. Why not '73?
Also, Jegs say's if the wrong motor mounts are used; some aftermarket headers will not fit.
Thank you very much,
Mike Griffin
Old 04-04-2006, 09:48 PM
issach428's Avatar
issach428 issach428 is offline
Just find a early second gen camaro. The subframes are almost identical on camaro and firebirds.
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane.
Old 04-05-2006, 05:22 AM
I don't understand your answer very well, could you elaborate?
Old 04-05-2006, 01:47 PM
WARPed's Avatar
WARPed WARPed is offline
You would use a 1970-74 Crowmarrow as your application for parts.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 04-05-2006, 06:08 PM
I'm not the brightest cat, are you saying just address it as Camaro when ordering parts? Since it is an F-body?
Old 04-06-2006, 09:50 PM
issach428's Avatar
you need the mounts off of the cross memeber of an early second gen camaro.
Old 04-07-2006, 03:54 AM
Will they be a bolt on application? Jeg's say's that maybe the mounts won't set on the frame in the same spots? I have the engine on the stand and ready to go. Tomorrow I'm pulling the 305 out of the bird.Will the th400 set down on the crossmember and bolt on?
Old 04-07-2006, 11:54 AM
Busster1's Avatar
Busster1 Busster1 is offline
Is the 305 you are refering to a sbc? If so you should have no problem because apparently someone has made a changeover. As for the th400 it is not a direct bolt in from a th350 / PG, the th400 requires a different crossmember. A trick to overcome the crossmember problem is to take the th350 crossmember cut the mounting tab off the front and reweld it to the rear side of the crossmember, or move it rearward and drill new holes in the subframe. Firebirds, and Camaro's share the exact same unibody in all respects therefore you just have to crossover the parts and part numbers accordingly you may have to drill an extra hole or two. Good luck.
Old 04-07-2006, 09:10 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
chevys belong in chevys and old fords...
Old 04-07-2006, 09:48 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Unhappy
This thread should be moved to the Non-Pontiac Motors . . . heading as well.
Moderators, please?
Regards,
"455HO" Lloyd
