Old 04-05-2006, 12:55 AM
OAKLEY389 OAKLEY389 is offline
Default HARD TOP OR COUPE
I JUST PURCHASED A 66 GOAT.ALL ORIGINAL.ANYONE KNOW WHAT THE DIFFERENCE IS BETWEEN A HARDTOP AND A COUPE?
Old 04-05-2006, 12:57 AM
mikediaz mikediaz is offline
i believe a hardtop has no post between the front and rear glass, while a coupe has a post there. With windows rolled up its not noticable but if you roll all windows down on a hardtop there will be nothing , on a coupe there should be a post there.
Somone correct me if i'm wrong.
Old 04-05-2006, 01:35 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Literary note: "hardtop" is short for "hardtop convertible". If you look at some of the early hardtop convertibles ('50 Chev, '51 Ford, etc.), it's pretty obvious that they are a convertible with a steel replica of a convertible top fixed in place. Convertible doors and windows are used. My favorites are some of the GM hardtops from '62-64, on which the roof was shaped just like a convertible top, with creases where the top bows would be. I also like the '54 Chevy BelAir hardtop, which had the inside headliner bows chromed to give an interior "feel" of a convertible's bows over your head.
Old 04-05-2006, 09:30 AM
64catdroptop's Avatar
64catdroptop 64catdroptop is offline
I always thought the hardtop and coupe where the same. My sources always refered to a hardtop and a Sedan. Hardtop - no post, Sedan - post
-r-
Never trust anything that bleeds for five days and won't die.
Old 04-05-2006, 10:20 AM
winbub's Avatar
winbub winbub is offline
MikeDiaz is correct in his description of differences betweenn a coupe and a hardtop. I own a coupe.
1966 GTO Coupe(#1845), AT, PS, PB, Nightwatch Blue
389 built by Gaydosh Performance - .040 over, 670 heads, 4bbl 750 Holley Double Pumper, Edelbrock Performer intake, Howards CAM and lifters, Scorpion roller rockers, TRW rods and pistons, Doug's headers, new TH350 with shift kit & 2000 stall, 8.2" rear with Auburn carrier & 3.55 posi Richmond gears
http://www.cardomain.com/ride/2240898/1966-pontiac-gto/
Old 04-05-2006, 11:05 AM
vidguy's Avatar
vidguy vidguy is offline
I always appreciated those as well.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 04-05-2006, 06:09 PM
ctgross ctgross is offline
What they said.....and
hdt.=24217
cpe= 24207.....and welcome to the site!
Post some pics when you can!!
CT Gross---66 GTO
"Its never too late to have a happy childhood"!
I told my dad I was going to stop raising hell, and he called me a quitter!
Old 04-05-2006, 10:08 PM
Thank you folks for the info.I will post pictures as soon as i can. This is a great site!
Old 04-06-2006, 01:19 AM
I purposely tried to avoid the "coupe" vs. "sedan" semantics, since no definitive answer exists. Up through the thirties (and even most of the forties) the two terms were quite succinct- a three-year old kid can tell a Model A coupe from a sedan. But at some point after that time, some idiot (employed by an auto maker?) applied the 'coupe' label to a vehicle that not only had a full back seat, but had virtually the same roof line as its companion 'sedan'- I'd like to shoot the guy!
Old 04-06-2006, 01:50 AM
Bryan Jensen's Avatar
Bryan Jensen Bryan Jensen is offline
On Vacation
Send a message via AIM to Bryan Jensen
Post post post!!!
I'm a little bias though, as I own one.
I guess you could really call them both, although the big difference between the 2 is that a hardtop can roll down all the windows to have a pillarless appearance.
Posts have a permanent supporting brace for the roof, and are I think a couple hundred pounds lighter??? I can't confirm that though.
Bryan
Old 04-06-2006, 08:38 AM
3 Deuce 64's Avatar
3 Deuce 64 3 Deuce 64 is offline
Send a message via AIM to 3 Deuce 64
1967 Production Numbers
Coupes 7,029 ( post)
Hardtops 65,176
Convertibles 9,517
Total 81,722
Old 04-11-2006, 03:36 AM
242177P's Avatar
242177P 242177P is offline
You can't confirm it cause it's WRONG. The weight difference, according to AMA specifications, is 5 (five) pounds!
