Old 04-06-2006, 03:48 PM
Aaron's65Tripower Aaron's65Tripower is offline
Default Lifter tick in my 65
Can anyone tell me what the lifters should be set at?
Old 04-07-2006, 12:34 PM
racerboy's Avatar
racerboy racerboy is offline
If you are running the stock rockers with the bottleneck studs, just tighten them to 20 ft-lb. and you're done.
if you're running BB chevy studs, check out:
http://forums.maxperformanceinc.com/...ock+rocker+arm for adjusting them to zero-lash.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
