Old 04-11-2006, 11:05 PM
big head big head is offline
Default accusump install pics
conton 3qtr accusump installed and ready to go. Watcha think..
ID:	49702   Click image for larger version
Old 04-12-2006, 01:04 AM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Is that a one way check valve installed at the block adaptor ???
If so please read my post in the race section on the valves. If not please disregard
Working on going faster (and now staying dry at the same time !!)
Old 04-12-2006, 07:56 PM
no check valve here ,your looking at the pressure sender port coupler.
Old 04-12-2006, 10:49 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
the oil will be prewarmed for your protection.
is this thing on?
Old 04-12-2006, 11:30 PM
I have a question reguarding the fuel system...It seems as tho you have the main fuel line coming in the front of the carb, and the regulator at the back AFTER the carb sees the pressure...Is this a better set up than running the fuel line to the regulator and then out to the carb?
Im asking because im planning on putting my regulator at the rear of my carb,, but I was going to run fuel in through regulator first and then to carb and bypass out of regulator...whats best?> this is for my turbo deal
Mike
