Old 04-12-2006, 08:10 PM
dave21042 dave21042 is offline
Default Recover Seat Myself or Pay Someone?
I purchased new seat covers and wondering if I should do it myself or pay someone. I called one shop and they said $400 to re-cover the seats with my components, is this a good price. It's a 69 Custom S Convertible with Bucket Seats.
Old 04-12-2006, 09:23 PM
rdk rdk is offline
I had mine done last year,with seat covers from PUI? I think, it cost 225.00 and was a very nice job
Old 04-12-2006, 09:32 PM
md1twal3 md1twal3 is offline
I don't know if $400 is a good price, but buy yourself some hog rings and a hog ring pliers and do it yourself if you already have the seat kit. Take your time and hog ring the covers in the right areas to avoid wrinkles and you should be fine.
I have done many and it really isn't all that hard...
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi
Old 04-12-2006, 09:48 PM
cnc's Avatar
cnc cnc is offline
Seat covering isn't that hard like mentioned keep note of hog ring postioning to keep out the wrinkles and have at her also helps if the underpadding is good.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 04-13-2006, 01:15 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
Lay the covers out in the sun so they will be easier to work with.
Old 04-13-2006, 02:36 AM
ChupaCabras's Avatar
ChupaCabras ChupaCabras is offline
I bought foam and PUI fronts for my '66. I skinned the back support area of one seat to the metal frame to see if I could do a good reasonable stab at it..the foam is "standard" for many cars and was not a perfect fit and I could easily tell it was going to be fun..not..the old foam also was dry and chalky and messy to work with...It took 30+ minutes just to get there. PUI intructions also noted to use burlap..lets see..nope..as expected I didnt have any burlap lying around... burlap hunting+good set of hog ring pliers+calculated time to do both seats (4-5 miserable hours)= not worth it. I have done a lot of work myself.. but as you get older you realize some things are best done by the pros... a local upholstery shop did both front seats for $150. they came back a LOT better that anything I could've done.. I provided PUI covers and foam.
Old 04-13-2006, 06:19 AM
carcollector's Avatar
carcollector carcollector is offline
This is not that hard. Before you start, make sure you have inspected your frames for rust and cracks. Order a zillion hog rings. Just trust me with that number. Hog ring pliers are a must. Also, have nearby a quality heavy gage wire cutter. Burlap is required between cushion and piano wire. Now, when your ready to install the warm cover, turn it inside out and slowly unfurl, tugging on it as you slide it down. For the seat cover, you can use that thin dry-cleaning plastic over your cushion and your seat cover will slide easily.
Hope this helps. Chris.
Reality is the ultimate payback
Old 04-13-2006, 09:41 AM
sharkbite's Avatar
sharkbite sharkbite is offline
You see them do it on the car shows all the time, doesn't seem that hard.
I 2nd what Colin said, "Lay the covers out in the sun so they will be easier to work with."
This world is your world, so take it, but take it easy.
Old 04-13-2006, 10:05 AM
eric65's Avatar
eric65 eric65 is offline
Default seat
check this book out about $13 on Amazon.com
http://www.amazon.com/gp/product/155...lance&n=283155
Has some nice instruction for DIY
I ordered and although havent done them yet it seems managable
Always gets down to money though and $400 or $150 is more for other stuff needed
twoponchos's Avatar
twoponchos twoponchos is offline
It is an easy install. Just do it yourself.
Old 04-13-2006, 11:35 AM
GTOster GTOster is offline
Did mine last year very easy
You need a good set of Hog Ring Plires a must to save your hands Belive Me
Set your covers in the sun it heat's them up and takes out winkles
After you get the foam on and you are ready to put covers on go find a friend
Putt a thin plastic bag over (From dry cleaners work best) seat padding and sprinkle talc power on the bag this will allow covers to slid on easy after the covers are on, pull plastic off from under the seat thin plastic will rip out very easy
Get a set of vicegripps pull the cover and have your friend set the hog ring
Repeat on other seat
Safety glasses are somthing to think about since hog rings DO FLY
Hope this helps
Paul
Old 04-13-2006, 01:44 PM
Thanks for all the input, I ordered the suggested book plus one other I had found. I think I will give it a try and see how I do, if I can't do a good enough job then I will pay someone. I'll try to post a few pics in case anyone wants to see them.
Thanks again.
Old 04-15-2006, 09:22 PM
autobahn autobahn is offline
If you have a digital camera take pics as it comes apart you can't miss doing that.
JIM
Old 04-16-2006, 06:59 AM
BlueGTO BlueGTO is offline
I jest did mine if your doing the fronts do one at a time it helps see how things go if in question.Dosent seem to be that hard take your time
Old 04-16-2006, 07:30 AM
firebirdcrazy1959's Avatar
firebirdcrazy1959 firebirdcrazy1959 is offline
Do it your self,take your time ,no beer while doing them!Just be clean and make sure their warm and will strech alittle.Buy a good hog ring tool also.i bought the best one i could find.I've done about a 100 or more seats,[i worked in a dealership].I would always put the covers in the sun to warm up.To me the hardest was leather covers,had to get them just right on the foam.I laid out a big clean sheet or a cardboard box to work on.
1977 Trans Am,400 4 speed,numbers matching car
1979 Bonneville ,1 owner car...
1997 Trans Am convertible,LT1/auto.
Old 04-23-2006, 09:38 PM
Default Got one seat done
Other than the headrest and the plastic trim, I finished one seat. The color is parchment, flash wahed it out and it looks white in the picture.
Thanks, to all who helped me with advice.
ID:	50927   Click image for larger version
Old 04-24-2006, 08:52 PM
Ron Landis's Avatar
Cool Nice ride!
John Sawruk once told me when I called him about an HO '69 Custom S convertible that it was one of the rarest Pontiacs made. I knew very little about Pontiacs at the time amd let the HO rengine and small cc "48's" get away. Good luck with you project. Ron
