Old 04-16-2006, 11:56 AM
Formula400NYC Formula400NYC is offline
Default Mounting Cal-tracs and split monos
I've heard that you need to fabricate some sort of spacer to run this set-up. Is this true, and if so what did you use. This is for a second gen bird.Thanks..
Old 04-16-2006, 12:14 PM
Ron's Avatar
Ron Ron is offline
It depends....it depends upon if you have mono or multi leaf springs. If you have multi leaf springs you will need spacers to take the place of the rubber spacers.
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 04-16-2006, 01:04 PM
Brian '74's Avatar
If you are using the stock 2nd gen perches then you will need to use a spacer to make up the difference. between the springs and the inside top of the perches.
Old 04-16-2006, 01:09 PM
I'm going from multi spring to mono spring. Does Cal-trac sell the spacers or do I have to fabricate something.
Old 04-16-2006, 02:04 PM
Ron's Avatar
Ron Ron is offline
You will have to fabricate them. What Calvert recommended to me was to change over to the Ford 9 inch leaf spring perch. That is what I did and no spacers were required.
Old 04-16-2006, 05:35 PM
Torment's Avatar
Torment Torment is offline
You can make them out of a chunk of aluminum or any other material suitable to pinch between the mounts and bars. I used a couple of chunks of industrial belting material, drilled and cut easy but doesn't compress, is light, and doesn't break down from road contaminants.
It's really not a big 'detail' to setting it up - simple caveman stuff.
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 04-17-2006, 11:49 AM
Torment, or anyone else, do you have pictures of your set-up? Thanks.....
Old 04-17-2006, 12:03 PM
Brian '74's Avatar
Found this:
http://forums.maxperformanceinc.com/...1&postcount=10
Old 04-17-2006, 01:25 PM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
The lowering/raising spacers used for trucks and circle track cars can work. I think Guldstrand the road race guy had some smaller thickness lowering blocks also.
Old 04-17-2006, 03:24 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
i had to make a spacer for mine..........
I was told by calvert racing that if your car was an
original mono leaf car you need the spacer made........
if it was a multi leaf car you dont.................
I forget the exact size ........cal tracs will tell you if you
call them...............and you also have to drill a hole in the middle
of the spacer so the pin on the leafs can go through...........
other than that mine went in very easy.
Old 04-17-2006, 05:18 PM
69redbird 69redbird is offline
you can get he blocks at speedwaymotors.com I believe you need the 1" blocks.( $ 8.95) Thanks
Old 04-17-2006, 09:13 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
formula, what springs are you running that are monoleafs?
is this thing on?
Old 04-18-2006, 01:17 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
What is a "split" monoleaf?
Old 04-18-2006, 07:13 AM
wrench's Avatar
wrench wrench is offline
http://www.calvertracing.com/lspring/leafspring.htm
Old 04-18-2006, 07:13 PM
Torment's Avatar
Sorry, not computer literate enough for pics...
Old 04-19-2006, 12:54 AM
Thanks for the link to Calvert Racing. Unless the two parts of the leaf are different spring rates (different thickness or width, or different material characteristics), I fail to see what's "revolutionary" about them, though. And even if the rates are different, I still don't consider it revolutionary- a bunch of us guys, 45 years ago, used to run less leaves behind the axle than in front of it.
Old 04-19-2006, 10:46 AM
MrPushrod's Avatar
what's revolutionary about them is that my small tire leaf spring car will hang the front hoops.
