this is my issue, i like to drive my Lemans cross country. but i love having 3200rpm stall at the strip. i was given a 2004r out of an SS Monte Carlo. i have read, here and there, that lockup converters give up some durability (not counting the big dollar units). now i expect my torque to be upwards of 500lbft at around 3200-3400 (not for sure till i hit the dyno). i still have the 3.23 gear and will step up to 9" ford for easy gear changes.
lets say i put the 2004r in and use a stall converter (32-3400rpm). will this negate the whole reason to have over drive (my th400 already gives me about 3000rpm at 70mph)? i guess i am woundering if i WILL need the lockup to get full advantage of overdrive without overheating my tranny fluid. or if driving at rpms below stall has any effect on trans fluid temp at all, or even if i can get my rpm below stall while on the interstate (i know i can do it cruising at about 35mph). i wish i knew it all like i thought i did about 10 years ago
The hallmark of a good converter is one that retains a high efficiency while at part throttle and only hits the stall at heavy throttle. So you would then, while driving easy around town or crusing on the highway, not notice you have a higher than stock stall speed converter. The cheap inefficient units will slip like crazy even at slight throttle, heating the hell out of the trans. So if you buy a good converter you can have your cake and eat it too.
With the .67 overdrive of the 2004R your 3000rpm at 70mph will drop to 2000. With the converter locked you can take another 200 or so rpm from that, so you will cruise at 70 at about 1800rpm. |
Just a few thoughts.
Still haven't mastered the quote functions
i should have mentioned that the 9" will go in before i put the the 2004r. so gear selection will be pretty wide open. i guess a simplified version to my question is...
can i run a stall of around 32-3400rpm in my 2004r, while maintaining steady "low rpm 70mph" cruising down the interstate, without burning up my tranny fluid? and if so, what is a good converter? i use a Boss Hogg 32-3400stall on my th400. thanks for the answers so far, i will look up Yank converters and others. the engine is a, bread and butter, 455. 6x-4 iron with ALOT of port work and chamber work. cam will be either my favorite solid flat tappet (290b-6) or a roller that i purchased from a member (308-r10). i know the cams are night and day, the flat tappet will most likely be the choice untill i finally get the "e-heads" i want. T2 intake, SRP and eagle internals. thanks, Michael. |
I went with guy that Pontiac Dude recommends; PTC in Alabama. They built me an awesome 10" lockup Nitrous converter which stalls at 3200 for $450. At light throttle you can't tell it is a higher stall converter. But it stalls when you get on the gas. If you google Kenny Ford or PTC, you will find that not only does Pontiac Dude recommend him, but there are tons of people out there singing his praise. One of the most common comments I saw was "He got the stall right first try." He got it right first try on mine too. However there are lots of good converter guys out there. One that many people on this forum people like is Continental Converters. |
