windshield removal?best technique
trying to decide the best way to get the front and rear windshield out of my 69 gto.Someone sells a removal kit but went to 4 different places and nobody has it.does anyone have a trick other than piano or guitar string(music store closed today-sunday)want to get this done asap to get the frame to the sandblaster.thought body will be much lighter with these removed,plus dont want them to crack.Im still not eactly sure how im gonna get the body off yet either.thanks for any and all replies.
I did both of mine with weed eater string and a screw driver wrapped a couple times as a handle. Worked great.
_____________________________ It is not a problem.... It is just a blood pressure monitor. |
thanks for the tip,ill give that a shot
A tool is made that is pretty much like what has been discribed. I like this method the best. I have a seal cutting tool that is a blade but it is easier to break the windshield with it. The wind shield is easy to crack so be veeeerrry carfull. I have a Paint and Body book that discribes using a putty knife from the inside, slowly working your way around, pushing in wiggling, removing and pushing in again. If your windshield is installed using windshield caulk this stuff is a real pain, dries very hard and hard to cut. Once again, try the wire tool .
Windshiled removal tool
I used a windshield removal tool. I had no problem, you just need to make sure you pull it slow, and keep downward pressure on the knife. If the glass has been installed in the last 20 or so years, they probably used urethane, weed whacker string will not cut it. Harbor Freight sells this tool.
i used to install auto glass............try this place..look at the cut out wire......http://www.equalizer.com/Merchant2/m...tore_Code=2004
I used one of these. Got it off of ebay pretty cheap. I've also seem them at some of the tool places at flea markets. Cut through the goop on my 67 like butter. Took me no time at all to remove my windshield.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
a great glass tool if you want to throw away the glass when its out..............................be very careful with this.....if it hits the glass it will chip it...........then you're done.
Mr. Pushrod- I've been using the pipeknife off that website you linked for years and its my favorite. After a few times you get a feel for "flexing" the utility blade in the channel and nothing is faster or more universal. well, unless you get one of those high $ heated blade thingies. The handle allows leverage but you have to be careful not to put pressure on the glass or "tick" and then you might as well just grab a hammer to finish the job. Sometimes I use the pipekife to cut away all the exposed adhesive to make the wire cut easier and sometimes the pipeknife can be used for the whole job. Depends on the shape of the windshield, the channel gap, interior panels, etc.
grdn24- I recommend practicing removal at a "yank and crank" junkyard to get a feel for it before doing your windshield- there is an endless supply of no-cost training. Also, nothing is harder than OE tapekits baked in the CA sun for 30 years. Bring extra blades. I got a MAC Tools 90 degree blade/cable/t-handle cutter like 67 455 and I tried it once and now its gathering dust. Not recommended. |
Pipe knives are great as well.......always use a new sharp blade.........
most people get ahead of themselves with pipe knives by going too fast and then...........there goes your dash or paint..........not fun. take your time removing glass, it's not a race.........I'd rather go slow than ruin my car...........I've put alot of windshields in old cars..........i think they're the easiest to do....... |
the new "urathane" is very hard once dried........
but it's the best. |
I think it's a whole lot easier to install with urethane since you can actually adjust the set after you place the glass where the tape kits you better get it right on first shot. Oh yeah, if it has a windshield antenna make sure the lead is in the right place before you set it. I've done that more than once. Another secret I learned over the years is to paint the windshield channel if you have to do alot of scraping. I see channel rustout here in California and I'm positive it starts from bare metal exposed during windshield replacement. |
urathane is the best and safest...... 90% of channel rust is from a retard putting in a windshield and not covering the scratches.............. the company 3M makes a one step PRIMER for scratches to prevent rust.... this is recommended!!! if you use paint it must be 110% dry before applying the urathane. |
ha ha, you got me Pushrod. I'm a old fart. There wasn't urethane when I started doing glasswork so we had to use paint. When I say paint now, I mean use this stuff. Why do I have 2? Because the little buggers are small and roll away, you buy another and then ta-da there's the first one.
Here is my trusty pipeknife. I tape extra blades to the neck I don't recommend this. Looks new, eh? If you look close the blade is bent AND twisted. That is why the glass breaks. I still hate hate rubber gaskets even using rope and windex unless they pop for a new one. I hope these pic's come out otherwise I'll feel pretty foolish |
oops, that's the glass primer. must be Alzheimers use the black lid 8684 for the channel like pushrod said.
Im with Bird Ragtop. Picked mine up at an OReillys for $10 or $15. Had my windshield and back window out in under 90 minutes. Tried an old guitar string and broom handles. Just about lost 3 fingers.
Bud Lawrenceville GA 73 Firebird 96 Impala SS |
i have the same pipeknife i would recommend a new blade for that pull knife try silicone instead of windex......or use a brand of glass cleaner like stoner, i think the stuff in a can is the best. |
I just used the handles from an old jump rope and threaded guitar wire through them. Have a helper on the inside and just work your way around the glass.
John
69 Firebird/TA clone |
