Old 05-17-2006, 03:21 PM
FormulaMan403's Avatar
FormulaMan403 FormulaMan403 is offline
Default Which heads for my 403??
I have a '78 Firebird Formula with the 403 and I was looking for some heads to swap over for more compression and performance...And I finally found a place that has 2 sets of heads, they have a pair of #5 heads and a pair of #7 heads. Which ones should I go with???
Anyways I can get the heads completetly assembled, drilled for bigger bolts and coolant passages for $300. But I was wondering If I should Have them port and polished first, Is this really a big deal?? or do they flow good enough to not worry about em??
Old 05-17-2006, 04:19 PM
gearbanger's Avatar
gearbanger gearbanger is offline
Does bulldog make a set for it? What about Edelbrocks or Mondello? There is alot of good parts out there for Olds.
Old 05-17-2006, 04:20 PM
gearbanger's Avatar
Sorry, I didn't read. I have no idea about the factory castings.
Old 05-17-2006, 05:30 PM
jfmjr1 jfmjr1 is offline
try this site
http://442.com/oldsfaq/ofe403.htm#E4...IDEngineDetail
It is from 442.com freequently asked questions section.
Also check section on Heads - will provide all that you need
From what you say your choices are, I would go with the 5's, if they are to be redone, which should be a 1969 (casting number 397742 located above center exhaust port) 350 SB head but check casting numbers and make sure they are 69's. The 7's would also work, and may also already have hardened seats for unleaded fuel
Hope that helps
John
1965 GTO Clone 455 4 spd
1970 442 Convertible 455 auto A/C
